Zum Hauptinhalt wechseln
Larger version of the Nintendo DSi, released March 2010 in North America. Most repairs are accomplished with only a screwdriver and prying tools.
156 Fragen Alle anzeigen
Top screen only works at a certain angle
The top screen only works at a certain angle, otherwise, it is either black or full of static. I think it may be an issue with the wiring especially because a part of the plastic protective shell has broken off around one of the hinges meaning they no longer work. What can I do to fix it? everything else is good.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi
You will need to replace the shell and screen assembly as there is a ribbon cable that flexes when you open and close the display and it sounds like that one has broken in your case
Here’s the teardown you will need
Nintendo DSi XL Teardown
You just need to follow it until your parts are replaced
Also if you leave me a comment saying what colour your ds is and where about a you are in the world I can get you the correct links to what you need
Hopefully this helps
Any questions please ask
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Monet Gagnon wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 100
