Zum Hauptinhalt wechseln
Die BCO430 von DeLonghi ist ein Kombinationsgerät aus einer Siebtträgermaschine und einem 10-Tassen Filterkaffeeautomat. Sie ist mit einem Milchaufschäumer ausgestattet. Farbe: schwarz/silber
There fog in my timer
Hello I made a cappuccino and I think some water spilled to the clock and is now foggy how do I fix it ?
Update (10/08/2022)
Can you see the images? not sure if it got uploaded properly
Update (10/08/2022)
Did these images come ok?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
Hi
Unfortunately there aren’t many options
You could leave it in a very dry environment until the moisture drys up
Or you could take it apart and see what the issue is from the inside(eg broken seal)
Unfortunately there aren’t many guides on taking it apart so if you decide to take it apart I can try and help guide you if you would like
Hopefully this helps
Any questions please ask
War diese Antwort hilfreich?
Bewertung 1
8 Kommentare:
Can you help me with replacing the boiler lid on this one? I am not able to figure out how to expose the boiler fully so that I can replace it. I am able to access it from the top, but that will not help me remove the boiler. Thanks in advance.
von Teilen
@valchrisfamily
If you can upload some photos of what stage of dissasembly you are at using this amazing guide I can try and guide you
Bilder zu einer vorhandenen Frage hinzufügen
von Teilen
Uploaded 4 pics. The last one shows a close up
Of the boiler where the water input nut is broken and needs to be replaced.
von Teilen
Also - I did open the bottom as on the video. It the video was solving a problem with the drip coffee maker. I could not find a way to open the espresso side of things.
Thanks for any tips.
von Teilen
@Valentine Christopher
Thanks for the images(they all came through just fine)
Let’s start by removing the 4 screws on the right side of top of the machine to see if that uncovers anything
(Just to let you know I haven’t actually worked on this specific device ,iv only ever worked on things similar to it, so I’m just using my repair knowledge and priory experience for these sorts of devices)
von Teilen
3 weitere Kommentare anzeigen
These coffee makers often are similar. Compare to Saeco Magic Capuccino SIN017 Boiler ausbauen and Starbucks barista , perhaps it helps. Good luck!
Starbucks Barista Bild
Anleitung
Starbucks Barista Teardown
Schwierigkeitsgrad:
Mittel
Saeco Magic Capuccino SIN017 Boiler ausbauen Bild
Anleitung
Schwierigkeitsgrad:
Mittel
Bewertung 1
Pics attached - this is how far I could get
Update (10/08/2022)
Bewertung 0
Update (10/08/2022)
Bewertung 0
Antwort hinzufügen
liluet_hernandez wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 25
Insgesamt: 516
