Zum Hauptinhalt wechseln
Das 2020 Mainstream-Smartphone von Apple kam am 23. Oktober heraus und verfügt über ein 6,1" OLED Display und ein 12 MP Zwei-Kamera-System und ist in fünf verschiedenen Farben erhältlich. Es ist der Nachfolger des iPhone 11.
Is this damaged or can I use it?
I am replacing the display IC from the original screen and scraped away the black layer of adhesive and what could have been the top layer of the chip. Is this still usable after reballing or is it damaged. Very new to this stuff. Thanks!
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi
When removing chips you will get some minor defects
It your case it looks ok as I can’t see any obvious bits of exposed copper or any chipped or dented bits of the chip
If you want to you could apply a very very thin layer of solder mask where it has been removed (if you do make sure to not get it in the pads,if you do you can carefully scrape it off the pads)to help if you have any on hand
I would put the chip on(after Reballing)and see if it works and if it doesn’t replace it with a new one as small chips like this aren’t expensive to replace:-)
Hopefully this helps
Any questions please ask
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
@hellomacos is correct. Apply solder mask than re-ball the IC as it does not seem damaged.
von
I wouldn't take a chance and waste your time the chip is only a couple of dollars so I would just replace it with a new one.
Bewertung 0
1 Kommentar:
Reball it and try it. Doesn't look too bad to be honest. You've gone this far. Let us know the outcome. Good luck.
von
Antwort hinzufügen
Salmaan Yehia wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 148
