Zum Hauptinhalt wechseln
Die Xbox 360 ist die zweite Spielekonsole der Firma Microsoft und erschien in Europa am 2. Dezember 2005.
428 Fragen Alle anzeigen
What does it mean when my xbox 360 has 3 red rings?
xbox 360 was playing games then all the sudden froze. it did this twice so i didnt play for a few days. then when i went to turn it on again 3 of the red rings turned on. the top left, bottom left and bottom right. what is wrong with my xbox 360?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Looks like a General Hardware Failure.
War diese Antwort hilfreich?
Bewertung 3
5 Kommentare:
The most common reason for this is that the solder connection from either the GPU or CPU is interrupted. A variation of the RROD. You can either try to use the RROD kit from here Xbox 360 Red Ring of Death Fix Kit or to reflow your board. Best and more permanent fix would be to reball it. Of course, do not forget that Microsoft may also repair your Xbox. If you have not cracked it open yet, you might want to give them a call and see what they have to say. Good Luck.
von
how do you re flow the board?
von
Check on here Reflow der Hauptplatine der Xbox 360 or do a search on Google ;-) plenty of tips and tricks out there.
von
ok well i tried redoing the thermopaste again and the red rings went away now the system freezes about 5 min after i turn it on
von
I would imagine that it freezes due to overheating. You may be looking for a bigger repair.
von
I dot have a answer i have a question. I have 3 rigs o mine now so do i let it sit for a long time or is it overheating?
Bewertung 0
Antwort hinzufügen
fiduccian wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 28
Insgesamt: 8,982
