This from here "Debris in disc drive
If your disc drive tray is stuck and will not open or close, then you have to manually eject the disc. Follow these instructions to remove the faceplate and manually eject the drive. Remove any obstructions, and plug the console back in. If the eject button still doesn't work, your disc drive may need to be replaced."
In general, for any optical drive, you want to check the following:
Stuck disc or other object in drive
Remove the disc
If there is a disc in the tray remove it.
Disc drive button broke
Bad drive gears
there is also the possibility that your drive does not read the disk (try other ones) and therefore opens the tray. That would also be connected to the flashing green light, since it indicated that your drive is trying to read a disk. You might try to clean the laser of your drive, or think about replacing your drive. Just remember "The Xbox 360 is designed so that the DVD drive works only with the particular game console it is installed in. Replacing a defective DVD drive with a replacement DVD drive does not work, since the replacement has a different DVD drive key, which the game console won't accept. ...Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
3
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
11 Kommentare
Does the CD drive shut all the way? Can you peer into the drive and see if the little "button" that detects when the tray shuts? Can you hear the drive motor straining even it is shut?
von Phillip Takahashi
hey did you ever fix your xbox? because mine is doing the exact same thing as yours. and i dont know what to do? i need help!
von Chris
Chris did you ever check out the site I recommended as one of the answers? You will find what you need to do there.
von Justin
My Xbox 360 will not stay close I really need help asap
von John phillips
Hi, I also have the same problem. My disc tray won't open. I need to open it with a paper clip each time. And now it doesn't close properly. I have to press it when it closes until it reads the game. I had a other xbox 360 that "red eyed" so i took out the disk drive and put it in my one. But it does not ready my disks. Can someone help please.
von charl
6 weitere Kommentare anzeigen
