Zum Hauptinhalt wechseln
Mid 2010 Modell A1278 / 2,4 oder 2,66 GHz Core 2 Duo Prozessor
MacBook Pro 2010 wont detect the lid closing and leaves the display on
My macbook Pro 2010 has been resotred, and I have fixed numberous probloms, but the lid closing and the display not sencing it bugs me. Is there any way to know what the problom is and troubleshoot? Btw there are still magnets in the right places such as the lid and to the sides of the trckpad?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
If you haven’t swapped-out the display (which is where the magnet is located) then there is only one other possibility the Hall sensor has failed or the ribbon cable which it is mounted to has.
You’ll heed this part MacBook Pro 13" Unibody (Mid 2009-Mid 2010) Hard Drive Cable and follow this guide MacBook Pro (13 Zoll, Mitte 2010, Unibody) Festplattenkabel tauschen
Besides the HD SATA connector this cable has the SIL LED and the Hall sensor is just above the LED pressing against the uppercase.
Fix an unrecognized drive in your MacBook Pro. This cable connects the hard drive to the logic board and is compatible with all Mid 2009 and Mid 2010 13" Unibody MacBook Pros. Bild
Produkt
$34.99
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Chase reitelbach wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 20
Insgesamt: 255
