Zum Hauptinhalt wechseln
Mit dem Wandel der Zeit hat Apple beim originalen USB-zu-Lightning-Kabel den USB-Anschluss durch einen USB-C-Anschluss ersetzt.
Can you make a USB-C to USB-C cable from 2 USB-C to Lightning cables?
With several old USB-C to Lightning cables and now no need for the lighting side of them, is it possible to cut off the lighting ends of two cables and splice them together to make a longer USB-C to USB-C cable?
It seems like with the circuitry and resistors already in place on the factory USB-C ends it would be a simple strip and solder job on the corresponding wires, but wanted to check with wiser minds here before trying.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi @spiralingshape
Here's a link showing the pinout for a USB-C cable.
This should help you to wire a USB-C connector in at the other end of the cable.
Not sure what you mean by "...with the circuitry and resistors already in place on the factory USB-C ends..." though.
There's only wires in the cables unless you meant in the USB-C controllers in the devices that they connect to.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Thanks! Regarding the ends of the cable, I assume there is circuitry in there to manage power and data properly. I also assume that if those ends are left alone (only splicing wires in the middle one-to-one) everything should function correctly. Just making sure I'm not missing something that might be in those cables that wouldn't allow for this type of combining.
von
@spiralingshape
All the power management is done by the USB-C controllers in the devices depending on what wire has a signal on it from the other end.
Click on the link underneath the pinout for more information about specific USB-C cable types as they can vary.
Just make sure that you don't reverse any connections i.e. wrong wire on wrong pin when testing from end to end
von
Hilfreichste Antwort
this might be helpful to you
USB-C to lightning wiring diagram
Bewertung 2
1 Kommentar:
Thanks, I saw that one, but since this isn't touching the ends of the cables, only soldering the wires in the middle, I wasn't sure if it was as simple as that or if there were any considerations about the cable functioning properly.
von
Antwort hinzufügen
spiralingshape wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 14
Letzte 30 Tage: 70
Insgesamt: 1,166
