Zum Hauptinhalt wechseln
Model A1318 / 32 or 64 GB capacity
299 Fragen Alle anzeigen
The bottom of the screen does not work
the bottom of my ipod screen does not work. when i try to touch an app at the bottom it does not respond. when i try to type a message the bottom row of keys will not respond. Help!!!!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
jblisset, try a restore. Make sure you have a backup of your data. If the restore does not work, I believe that you are due for a new digitizer. The best way to replace it is by installing the complete assembly. Instructions are hereand the part is here. Hope this helps, good luck.
iPod touch (3rd Gen) Front Panel Assembly Bild
Produkt
$29.99
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
Thanks the new screen worked!!!!!!!!
von
my ipod is the same but i havent been able to use any space or the symbol or anything else i can use the words but thats about it i think its the sensor is it time to get a new ipod or? its a 4 generation thanks
von
@marikah, replace the front display panel. It does sound like your digitizer is broken.
von
how exactly do you restore?
Bewertung 0
Antwort hinzufügen
jblisset wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 5,409
