Zum Hauptinhalt wechseln
How do I reapply thermal paste on this laptop?
Hello, my laptop's CPU often heats up to 70-80 when gaming, this did not happen before. I want to reapply the thermal paste on the CPU with hope of it lowering these temps. When i search on google i get multiple different answers as to how i should apply the thermal paste, and which thermal paste i should use (Some even recommend thermal pads)
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @superres7
Here's the hardware maintenance manual for the laptop.
First go to p.60 to see how to disable the built in battery and then go to p.66 to view the procedure to remove/replace the thermal fan assembly so that you can refresh the thermal paste on the CPU.
If necessary you can also clean the fan once it is removed from the laptop as well.
Here's the ifixit Wie trage ich Wärmeleitpaste am besten auf guide that may help.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
SuperRes7 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 5
Insgesamt: 81
