Zum Hauptinhalt wechseln
Anleitungen zur Reparatur und Fehlersuche bei der FixHub Power Series | Tragbaren Lötstation, bestehend aus Multifunktionaler Powerstation und Intelligentem Lötkolben. Erhältlich seit Mitte Oktober 2024.
Ifixit Soldering Station Problems keeps disconnecting
So i bought a Ifixit Hub and within in a week both tips failed and i was getting battery errors showing on the hub, so contacted ifixit and they sent me out a replacement hub and iron. But sadly this one did not work either, after playing around for a few hours i found that i had to keep unplugging the usb c until the iron registered with the hub then i would have to unplug the tip a few times to get it top actually work.
I was then asked to update the firmware but then found out the updater was switched off due to a current firmware issue, but they have fixed that now and i was able to update the firmware. The Soldering iron does seem a little better but i still have to unplug it a few times to actaully get it to work. When i switch the hub on the iron shows as connected and the temp shows but as soon as i switch the iron on it disconnects and i have to unplug it a few times to get it to work again.
Has anyone else had this issue and found the way to fix this?
I love the design etc but i need it to just work!
Sadly contacting for support is very slow and can take a few days just to get a reply to say update firmware, or have you tried removing the tip etc, basically the first things you would check and not need to be told to check! They really need a dedicated support email
Ist dies eine gute Frage?
Bewertung 3
5 Kommentare
@econut, sorry to hear about this. Let me check in with the team to see what we can do to get this fixed for you.
von
Thankyou, i really want to keep and use this soldering iron but in its current state its not usuable day to day as its time consuming trying to get it to work each time, or you will be in the middle of something and have to cycle through the routine of disconnecting etc to get it to work again.
von
I have the same problem :-(
von
Same problems here.
Either it doesn't recognize the cable at all, then there will be the "tool error actuator fault" etc. etc.
This is pretty disappointing, considering the pricetag and that i basically just unwrapped it.
What seems to - sometimes - make it work is holding the soldering iron like a chopstick and applying some pressure using my thumb near the color ring on one side. That suggests, to me, some kind of connection issue / cable break / ...
Anyways, can anyone from Ifixit let me know how to proceed from here?
von
@krisrodriguez so do you have any updates on this please as you can see its a common issue and I am getting no where emailing sales.
I love the design and the idea but this is an issue that we need some answers on please considering the cost, i have now spent over £350 on this due to having to buy more tips etc and this is un acceptable considering this cost.
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
I hope that you had a resolution to this issue, in the form of a replacement iron. While we have released many firmware updates since then to minimize the interruptions and severity of the issues that you've seen, the root of this issue comes from poor contact between the tip TRS connector and the socket on the main board. While a rare occurrence, we discovered this issue during manufacturing and have implemented design changes to eliminate the possibility of this occurring anymore. However, it unfortunately looks like you got a unit that slipped through the screening process.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
@brett Is there any kind of procedure on how to get replacement irons for these faults? I believe i have a unit (from preorder) that also exhibits this behavior, more so with one tip than with the other - but it still interrupts my workflow.
Please let me know - Thank you!
von
I just received mine on July 12, 2026, and right out of the box, it wouldn't work with the supplied USB-C cable. I updated the soldering iron using a different cable, and once the update was successful, I noticed what felt like a loose connection at the iron's USB-C port. I plugged the original cable back in, and the iron worked. I managed to complete two solder joints, but now the station is displaying a "Tool Error" message. I suspect a bad connection at the port, but I’m disappointed with the device's quality given the price... I had already filed a warranty claim for the cable, but now I’ll have to try to modify the request to get the soldering iron itself replaced...
von
@econut, thanks for your patience. We’ve just released the latest firmware update, which is now available for download.
If you’d like to try the update to see if it resolves the issue, please do. If not, feel free to reach out to me directly at community@ifixit.com, and we can arrange a replacement or start the return/refund process for you.
Bewertung 0
2 Kommentare:
Hub and iron are on 1.07 and update says that this is the latest version.
von
@andreasm68907, are you still seeing that the latest version is 1.07?
von
Antwort hinzufügen
EcoNut wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 22
Insgesamt: 748
