Zum Hauptinhalt wechseln
Anleitungen zur Reparatur und Fehlersuche bei der FixHub Power Series | Tragbaren Lötstation, bestehend aus Multifunktionaler Powerstation und Intelligentem Lötkolben. Erhältlich seit Mitte Oktober 2024.
11 Fragen Alle anzeigen
FixHub won’t charge out of the box.
Just opened up my set I got as a gift. The iron works great but the hub won’t charge. I put it on a charger that reports draw and it just keeps cycling on an off at 0.1w. I also tried to connect it to my computer to see if the online tool worked but no luck. I have also tried 3 other usb c cables to no luck. I also took the unit apart and disconnected and reconnected the battery.
Guessing I may have a lemon but wanted to check here first…
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
3 Kommentare
@justinm36946, Sorry about this. This is not the experience we want you to have. @jayeff is correct, please contact support@ifixit.com to get you back on track.
von
@krisrodriguez Sounds good. I sent a message when I wrote this as well. Though I have not heard anything yet. What is the usual support turn around time?
von
@justinm36946, we do our best to get back to you within 48 business hours. Please keep in mind that we're a small team so response times can vary from time to time. If you don't receive a response within that timeframe, you can reach out to me here in this thread, and I'll follow-up with the support team on the delay.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @justinm36946
There seems to be teething problems with the device, as you're not the only one having some problems with it.
Contact ifixit on support@ifixit.com and check if there's a solution available
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
justinm wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 12
Letzte 30 Tage: 18
Insgesamt: 57
