Zum Hauptinhalt wechseln
Was ist in einem Prozessor? Wie funktioniert er? Prozessoren werden auch IC (Integrated Circuits dt. Integrierte Schaltkreise) oder Microchips genannt.
Help Identifying a chip
Hello, I have a Vizio S2920w Soundbar which has a blown chip on it. I was wondering if anyone here could help identify it. Its marked 9F 2 and has U7 written on the board beside it. All help would be appreciated!
Ist dies eine gute Frage?
Bewertung 1
3 Kommentare:
Hi, I’m having the same problem. Were you able to identify the component? That would be a great help.
von
@albert45304 from whatever is left to identify the component, this could very well be a Voltage regulator. Check on here You can relatively easy identify if it is a V Reg if one of the middle pins looks a bit odd. Again datasheet will show what I mean by that. You can also desolder the component and check the bottom side for what the center pins look like.
von
@oldturkey03 Thanks, that was really helpful. It’s definitely one of these.
von
Einen Kommentar hinzufügen
1 Antwort
It looks like you have some other material to remove and underneath that there are the actual identifying markings.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Unfortunately I cannot remove that as thats the actual plastic itself which has burnt and turned white.
von
Antwort hinzufügen
TechVid wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 16
Insgesamt: 232
