Zum Hauptinhalt wechseln
Das ZOYI ZT-703S vereint die Funktionen eines Oszilloskops, eines Signalgenerators und eines Multimeters und ist damit ein vielseitiges Gerät für unterschiedlichste Einsatzbereiche.
Multimeter function is not working
Hello. I have a ZT-703S with a problem: the oscilloscope function works fine, all buttons work, and it takes measurements normally. However, when I switch to the multimeter function, only a few windows appear, including the analog scale, but no numbers appear. It no longer responds to functions like diode, resistance, and voltage. I updated the firmware and reset the settings to factory settings, but it still hasn't returned to normal. Does anyone know how to fix this?
Ist dies eine gute Frage?
Bewertung 0
4 Kommentare:
Hi @brunogouve48763
had you checked the internal fuse?
von
Yes, I checked the fuses, they are ok. I haven't found the solution yet.
von
Isn't the issue in below Youtube video a similar issue as what you have?
https://www.youtube.com/watch?v=P6QntvNA...
He was a able to fix it by re-soldering the chip.
von
Hello!
Yes, the same problem as in the video.
However, I resoldered the component as instructed in the video, and it didn't work. When measuring with an oscilloscope, there are frequencies in the transformer's primary and secondary. But it still doesn't work.
von
Einen Kommentar hinzufügen
1 Antwort
Ah OK, sorry to hear it didn't work for you.
Sorry that I can't be of more help.
Hopefully there are others who can.
Good luck!
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Bruno Gouvea de Paula wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 20
Letzte 30 Tage: 44
Insgesamt: 423
