Zum Hauptinhalt wechseln
Reparaturanleitungen, Demontage und Fehlersuche für die portable drahtlose Maus Logitech MX Anywhere 3S. Erschienen im Dezember 2023 und identifiziert durch Teilenummern 910-006925, 910-006926, 910-006927 oder 910-006928, je nach Farbe. Nachfolger der MX Anywhere 3.
Left button not working
The left button intermittently works and has been getting progressively worse over time. Should I follow the disassembly steps as described to replace the battery and try and clean the buttons with compressed air?
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @mcfb, if the Logitech MX Anywhere 3S is still under warranty, I recommend sending it in for repair. Based on my experience, once the warranty has expired the usual fix is replacing the microswitch. The part commonly used is an Omron D2FC-F-7N or similar, which requires desoldering the old switch and soldering in the new one.
War diese Antwort hilfreich?
Bewertung 3
4 Kommentare:
Thanks @augustine, I'm chasing warranty - I'll see how that goes first. Thanks for the help.
von
Is this a common problem with this model?
von
I have the same problem with left click, i'm going to try to repair the button. (Tape was not the issue, it was 100% the button malfunctioning)
von
This can't be true, those switches are substantially larger than the ones present in the MX Anywhere 3S
von
Antwort hinzufügen
mcfb wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 29
Letzte 30 Tage: 130
Insgesamt: 955
