Zum Hauptinhalt wechseln
Dies ist die fünfte Generation des Honda CR-V.
Front Radar sensor errors
My front Radar sensor is giving my errors, I cannot use my cruise control. How can I fix this issue
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
@ericgibson86652 Year? That would help us A LOT. And can you give us the error codes?
von
Einen Kommentar hinzufügen
1 Antwort
I had the same problem with my 2022 CR-V hybrid sport touring model. It happens mostly in rain or foggy conditions. More than likely it has to do with the camera above rear view mirror. With the placement behind the windshield in its own sealed enclosure, it tends to fog up, blocking the view, fooling the system into thinking you’re in a low visibility situation. It’s a design issue which was addressed in later models, such as my 2026. There is no permanent fix, but running your defogger on high when you first start out, to warm up the windshield may help.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Eric Gibson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 50
Insgesamt: 50
