Zum Hauptinhalt wechseln
Repaturanleitungen, Informationen zum Zerlegen und Problemlösungen für die Joy-Con 2 Kontroller von Nintendos Switch 2.
ZL Button Spring not working
I am trying to reassemble the left Joycon 2, and when I want to attach the ZL button, it feels like the spring is not doing its work. The ZL button is really steady and almost rubbing the button, so with a little touch it will press it.
Update (09/28/26)
Hello,
I was changing the covers. At the end I found the issue. The flex was not seating well on the support. From the top it looked like it was in the support, but I saw it sideways and it was not. This is why the ZL button was almost touching the button.
Thank you for reaching out!
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Hi!
Glad that you figured it out :)! Have a great day!
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi!
Please follow this to step 13: Joy-Con 2 (links) Joystick tauschen
Could you show us how the spring look like?
What is the reason you opened it? Is another shell used or is this a cover that you have put on?
I know that some shells do not fit completely and could cause this as well.
Thanks!
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
David Sandoval Galiana wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 25
Letzte 30 Tage: 25
Insgesamt: 18
