Zum Hauptinhalt wechseln
Trackpad Button Not working But keyboard is Fine
Hi
My trackpad Botton seems to be not working correctly , I have spent Hours on Google and many people seem to have same problem But there keyboard is Not working also . where my keyboard seems to be working fine ..
Basically when I use the button it grabs and does not let go , i can push the button 5-10 times and will eventually let go but seems slowly getting worst ..
I have read posts about putting a Paper under the Cable But this does not seem to work - But the other small Flat Cable from the button to the trackpad circuit - if i wiggle seems to let go , paper or nothing seems to help .. the actual trackpad seems Ok does occasionally also Grab and not let go but not as much as the Button ..
I have read That you can replace the whole Cable to the Track Pad - But can you replace the small cable from trackpad to the Button ??
Nothing has been spilt on the Computer and I have tried cleaning under and around the button with a piece of paper etc ..
So does anyone have any suggestions - can I replace the small cable ? or do I have to Buy a whole top case or the main Trackpad cable ??
Thanks Mark
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
If you can find the parts you could replace them - a simple fast workaround is a bluetooth or USB mouse.
''If this answer was helpful please remember to return an mark it Accepted.
War diese Antwort hilfreich?
Bewertung 0
Sounds like it's out of adjustment, there is a silver torx that you can adjust the pressure for the click if it feel flat no matter what the you need to replace the trackpad
Bewertung 0
Antwort hinzufügen
Mark Watts wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 2,218
