Back Panel
Beliebte Fragen im Forum
Eine Frage stellenEs gibt noch keine Fragen. Stelle du die erste!
Werkzeuge
Es werden ein paar gängige Werkzeuge verwendet, um an diesem Gerät zu arbeiten. Du wirst nicht jedes Werkzeug für jeden Schritt benötigen.
Troubleshooting
Diagnose problems with your Toshiba Satellite S55t-C5225 laptop using the troubleshooting page.
Background
The Toshiba Satellite S55t-C5225 is an all-purpose entertainment laptop with a brushed metal finish on the exterior and a black plastic bottom which was first released in 2015. With a 15.6in diagonal widescreen TruBrite TFT display at 1920 x 1080 native resolution (FHD), the screen can support 1080p which is ideal for multiple tasks. The current operating system is Windows 10 home.
This laptop has built-in harman/kardon® stereo speakers with DTS Sound technology. The device also features an optical disk drive, a front facing webcam, and is Bluetooth capable. This laptop is also RoHS compatible, ENERGY STAR qualified, and EPEAT Gold Rated.
The Toshiba Software and Utilities that are already installed are TOSHIBAecoUtilityTM, TOSHIBAMediaPlayerbysMedioTruelink+, TOSHIBADisplayUtility, TOSHIBAServiceStation, TOSHIBAPasswordUtility, TOSHIBAPCHealthMonitor, TOSHIBAResolution+UpconvertTechnologyforMediaPlayer.
Identification
The Toshiba Satellite S55t-C5225 model number is found on the manufacturer label on the bottom case of the laptop.
Specifications
Physical Description
- Dimension: 14.96 x 10.23 x 0.93in or 380x259x23.5mm ( W x D x H Front/H Rear)
- Weight: 5.18 lbs/2.35 kgs
Storage
- 1TB (5400 RPM) Serial ATA hard disk drive
Communications
- HD webcam
- TruTalkTM dual microphones with beam forming technology
- 10/100/1000 Ethernet
- Intel® Dual-Band Wireless-AC 726510
- Bluetooth 4.1
Memory
- 12GB DDR3L 1600 MHz (not user upgradeable)
Display
- 15.6 in diagonal widescreen TruBrite TFT display at 1920 x 1080 native resolution (FHD)
- Touchscreen
- LED backlit
- 16:9 aspect ratio
Ports
- Video
- HDMI with 4K Ultra HD output capacity
- Audio
- Headphone/Microphone jack
- Data
- 3 USB
- RJ-45 LAN port
Power
- 4cell/45Wh Lithium Ion battery pack (non user replaceable battery)
- 45W (19V 3.42A) 100-240V/50-60Hz AC Adapter
Source: Detailed Specifications
Additional Information
Manual and Specification Guides
