Zum Hauptinhalt wechseln
Dell Inspiron 13-5368 Battery Replacement
Was du brauchst
  1. Dell Inspiron 13-5368 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 13-5368 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
  2. Dell Inspiron 13-5368 Battery Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 13-5368 Battery Replacement: Schritt 2, Bild 2 von 2
    • Use a spudger to pry up and remove the back cover.
  3. Dell Inspiron 13-5368 Battery Replacement: Schritt 3, Bild 1 von 1
    • Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
  4. Dell Inspiron 13-5368 Battery Replacement: Schritt 4, Bild 1 von 1
    • Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
    • Pull the tab parallel to the motherboard, not straight up.
  5. Dell Inspiron 13-5368 Battery Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 13-5368 Battery Replacement: Schritt 5, Bild 2 von 2
    • Remove the battery.
Abschluss
For optimal performance, after completing this guide, calibrate your newly installed battery.
14 weitere Nutzer:innen haben diese Anleitung absolviert.
Matt Sugrim
1.042 Reputation
6 Anleitungen geschrieben
USF Tampa, Team S14-G6, Boczar Fall 2017 Mitglied von USF Tampa, Team S14-G6, Boczar Fall 2017
USFT-BOCZAR-F17S14G6
4 Mitglieder
13 Anleitungen geschrieben
3 Kommentare
Awesome, very user friendly instructions. Was not looking forward to taking to computer repair store to replace internal battery. Thank you so much for these instructions.
rdcath - Antwort
The new battery replacement does not come with a cable to attach to the motherboard. How can I use the cable from the old battery?
BilboBaggins314 - Antwort
I have this same question^. Can I reuse the cable from the old battery?
Gloria Kolyabin -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 12
Letzte 7 Tage: 44
Letzte 30 Tage: 212
Insgesamt: 24,415
