Zum Hauptinhalt wechseln
Dell Inspiron 15 5577 Gaming Battery Replacement
Was du brauchst
  1. Dell Inspiron 15 5577 Gaming Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Unscrew the back cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 15 5577 Gaming Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the back cover using an opening tool.
  3. Dell Inspiron 15 5577 Gaming Battery Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron 15 5577 Gaming Battery Replacement: Schritt 3, Bild 2 von 2
    • Use a T8 Torx driver to remove the five screws around the battery.
  4. Dell Inspiron 15 5577 Gaming Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove the Battery Cable by gently tugging it perpendicular from the surface it is attached to.
  5. Dell Inspiron 15 5577 Gaming Battery Replacement: Schritt 5, Bild 1 von 1
    • Pull the battery out of the laptop by prying it away from the laptop. If you're having difficulty removing it, you can also use a plastic opening tool.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
[deleted]
346 Reputation
2 Anleitungen geschrieben
Ein Kommentar
Thank you, you guys rock
Random User - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 47
Insgesamt: 5,149
