Zum Hauptinhalt wechseln
Dell Inspiron 15-7547 Battery Replacement
Was du brauchst
  1. Dell Inspiron 15-7547 Battery Replacement, Bottom Cover: Schritt 1, Bild 1 von 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 Battery Replacement: Schritt 2, Bild 1 von 1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 Battery Replacement, Battery: Schritt 3, Bild 1 von 2 Dell Inspiron 15-7547 Battery Replacement, Battery: Schritt 3, Bild 2 von 2
    • Remove the five 5.0 mm-long Philips #0 screws that connect the battery to the case.
  4. Dell Inspiron 15-7547 Battery Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 15-7547 Battery Replacement: Schritt 4, Bild 2 von 2
    • Lift the battery out of the case.
  5. Dell Inspiron 15-7547 Battery Replacement: Schritt 5, Bild 1 von 3 Dell Inspiron 15-7547 Battery Replacement: Schritt 5, Bild 2 von 3 Dell Inspiron 15-7547 Battery Replacement: Schritt 5, Bild 3 von 3
    • Pull the battery cable's pull tab towards the battery to disconnect it from the motherboard.
    • Pull parallel to the motherboard, not straight up.
    • Most of the cable is attached to the case with adhesive, which may cause slight resistance.
    • Remove the battery.
Abschluss
For optimal performance, after completing this guide, calibrate your newly installed battery.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Claro
591 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 24
Insgesamt: 2,035
