Zum Hauptinhalt wechseln
Dell Inspiron 15-7559 Battery Replacement
Was du brauchst
  1. Dell Inspiron 15-7559 Battery Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to turn off the device and disconnect the cable could lead to personal injury or device damage.
    • Flip the computer upside down.
  2. Dell Inspiron 15-7559 Battery Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 15-7559 Battery Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 15-7559 Battery Replacement: Schritt 2, Bild 3 von 3
    • Remove the captive screw located on the top section of the back panel, using a Philips #1 screwdriver.
    • Keep in mind that the screw cannot be fully removed from the panel, even when fully loosened.
  3. Dell Inspiron 15-7559 Battery Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron 15-7559 Battery Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron 15-7559 Battery Replacement: Schritt 3, Bild 3 von 3
    • Use the blue, plastic opening tool to gently pry a section of the back panel open.
    • Next slide the opening tool around the back panel to disconnect the clips holding the panel in place.
    • After the clips have been disconnected, the back panel can then be easily lifted off the computer.
  4. Dell Inspiron 15-7559 Battery Replacement, Battery: Schritt 4, Bild 1 von 1
    • Locate the battery on the bottom left side of the laptop.
  5. Dell Inspiron 15-7559 Battery Replacement: Schritt 5, Bild 1 von 3 Dell Inspiron 15-7559 Battery Replacement: Schritt 5, Bild 2 von 3 Dell Inspiron 15-7559 Battery Replacement: Schritt 5, Bild 3 von 3
    • Unscrew the 5 x 2mm x 5mm screws, using the T8 Torx screwdriver.
  6. Dell Inspiron 15-7559 Battery Replacement: Schritt 6, Bild 1 von 3 Dell Inspiron 15-7559 Battery Replacement: Schritt 6, Bild 2 von 3 Dell Inspiron 15-7559 Battery Replacement: Schritt 6, Bild 3 von 3
    • Using the tab above the battery, raise the battery far enough to disconnect the cables attached to it.
    • Using your hand grab the white portion connecting the cables to the battery and disconnect it.
    • Do not pull on the cables directly. This would risk damaging them or tearing them from the device.
  7. Dell Inspiron 15-7559 Battery Replacement: Schritt 7, Bild 1 von 1
    • Now lift the battery from the device to remove it.
Abschluss
11 weitere Nutzer:innen haben diese Anleitung absolviert.
UW Tacoma, Team S3-G2, Liner Fall 2017 Mitglied von UW Tacoma, Team S3-G2, Liner Fall 2017
UWT-LINER-F17S3G2
5 Mitglieder
9 Anleitungen geschrieben
2 Kommentare
Cool, that’s the easy part. How do you tell the UEFI that it’s okay to charge the new battery?
Stefan Bacon - Antwort
is it ok to replace the 11.4V battery with the 11.1V version?
Payton DePietro - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 15
Letzte 30 Tage: 71
Insgesamt: 16,317
