Zum Hauptinhalt wechseln
HP 250 G7 Battery Replacement
Was du brauchst
  1. HP 250 G7 Battery Replacement, Lower Case: Schritt 1, Bild 1 von 2 HP 250 G7 Battery Replacement, Lower Case: Schritt 1, Bild 2 von 2
    • Unplug the charger and all peripheries. Shut down the laptop before beginning disassembly.
    • Flip the laptop so its underside is facing up.
    • Use a hair dryer to lightly heat the rubber feet.
    • Use a spudger to lift and remove the rubber feet.
    • If you intend to reuse the feet, take care not to tear or warp the rubber feet during removal. Reapply adhesive during reinstallation.
    Frag FixBot
    Kommentar hinzufügen
  2. HP 250 G7 Battery Replacement: Schritt 2, Bild 1 von 3 HP 250 G7 Battery Replacement: Schritt 2, Bild 2 von 3 HP 250 G7 Battery Replacement: Schritt 2, Bild 3 von 3
    • Remove the eleven 9 mm-long Phillips #1 screws securing the lower case.
    Frag FixBot
  3. HP 250 G7 Battery Replacement: Schritt 3, Bild 1 von 3 HP 250 G7 Battery Replacement: Schritt 3, Bild 2 von 3 HP 250 G7 Battery Replacement: Schritt 3, Bild 3 von 3
    • Insert an opening pick or opening tool into the seam between the lower case and palm rest assembly.
    • Slide the opening pick around the entire perimeter, while prying every couple of centimeters to release the retaining clips.
    • Remove the lower case.
    Frag FixBot
  4. HP 250 G7 Battery Replacement, Battery: Schritt 4, Bild 1 von 1
    • Remove the three 8 mm-long Phillips #1 screws securing the battery.
    Frag FixBot
  5. HP 250 G7 Battery Replacement: Schritt 5, Bild 1 von 2 HP 250 G7 Battery Replacement: Schritt 5, Bild 2 von 2
    • Lift the battery up and away from the connector.
    • Remove the battery.
    Frag FixBot
Abschluss
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 27
Letzte 30 Tage: 28
Insgesamt: 117
