Zum Hauptinhalt wechseln
HP ProBook 640 G3 Battery Replacement
Was du brauchst
  1. HP ProBook 640 G3 Battery Replacement, Lower Case: Schritt 1, Bild 1 von 3 HP ProBook 640 G3 Battery Replacement, Lower Case: Schritt 1, Bild 2 von 3 HP ProBook 640 G3 Battery Replacement, Lower Case: Schritt 1, Bild 3 von 3
    • Before beginning, power the device down and disconnect all peripheries.
    • Remove the eight 6 mm-long Phillips screws securing the lower case.
    • Insert an opening pick into the seam between the lower case and chassis.
    • Slide the pick around the entire perimeter of the device until the lower case releases.
    • Remove the lower case.
    Frag FixBot
    Kommentar hinzufügen
  2. HP ProBook 640 G3 Battery Replacement, Battery: Schritt 2, Bild 1 von 3 HP ProBook 640 G3 Battery Replacement, Battery: Schritt 2, Bild 2 von 3 HP ProBook 640 G3 Battery Replacement, Battery: Schritt 2, Bild 3 von 3
    • Use a Phillips screwdriver to loosen the seven 6 mm-long captive screws securing the battery.
    • These screws are built into the edges of the battery, so they only need to be loosened in order for the battery to be taken out.
    Frag FixBot
  3. HP ProBook 640 G3 Battery Replacement: Schritt 3, Bild 1 von 3 HP ProBook 640 G3 Battery Replacement: Schritt 3, Bild 2 von 3 HP ProBook 640 G3 Battery Replacement: Schritt 3, Bild 3 von 3
    • Remove the battery.
    • If the battery will not come out, you may need to loosen the screws more; refer back to step 2.
    Frag FixBot
Abschluss
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
UMass Dartmouth, Team 1-7, Botvin Fall 2025 Mitglied von UMass Dartmouth, Team 1-7, Botvin Fall 2025
UMASSD-BOTVIN-F25S1G7
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 37
Insgesamt: 215
