Einleitung
A short battery life on the HP Stream 13-c010nr is a common problem experienced. Follow this guide to do the replacement yourself.
Was du brauchst
Remove the five rubber feet from the bottom of the laptop with a plastic opening tool.
Flip the laptop over and open it up.
Wedge a plastic opening tool between the keyboard and bottom case, pry upwards to separate the two pieces.
Lift up the keyboard.
Use a spudger to flip up the retaining flaps on the keyboard ribbon cable ZIF sockets.
Pull up the ribbon cables from their sockets.
Remove the eight 5mm Phillips #0 screws from the battery.
Disconnect the battery from the motherboard.
Pull the battery up and out of the laptop.
Eine weitere Person hat diese Anleitung absolviert.
