Einleitung
Use this guide to diagnose and repair an iPhone that won't start on battery power, but shows the Apple logo in a loop when connected to a charger. This symptom can happen when the battery is deeply discharged, damaged, unable to supply current, or unable to communicate with the logic board. The current-draw diagnosis can apply to the iPhone 4, 4S, 5, 5C, 5S, and newer iPhone models, but the disassembly shown here is written for an iPhone 4S. Other iPhone models may open differently and use different screws.
Was du brauchst
Schritt 1 Confirm the bootloop symptom
Press the power button with the iPhone unplugged and check whether the screen stays dark.
Connect the iPhone to a charging cable or charging station with a current display.
Watch for an Apple logo that appears, disappears, and repeats without the phone starting.
Schritt 3 Remove the rear case
Use a pentalobe screwdriver or T5 Torx screwdriver to remove the two bottom screws.
Press the rear case and slide it toward the top edge by a few millimeters.
Lift the rear case away from the iPhone.
Schritt 4 Disconnect the battery
Use a Phillips screwdriver to remove the two screws near the battery connector.
Lift the battery connector from its socket with a fingernail, nylon tool, or plastic tool.
Use tweezers to remove the small contact near the battery connector.
Schritt 5 Remove the battery
Pull the battery removal tab if it is still attached and strong enough to lift the battery.
If the tab is missing or broken, slide a long flat plastic tool under the battery from the outer edge.
Lever the battery up slowly until the old adhesive releases.
Schritt 6 Prepare the adhesive
Remove the old battery adhesive and any broken pull tab pieces from the battery well.
Apply fresh double-sided adhesive where the new battery will sit.
Cut oversized adhesive to fit the battery area.
Use tweezers to peel one liner from the adhesive.
Schritt 7 Apply the adhesive
Place the exposed side of the adhesive in the battery well.
Press the adhesive down lightly so it bonds to the case.
Warm the adhesive very lightly with a heat source if it needs help sticking.
Peel off the remaining adhesive liner while the adhesive is slightly warm.
Schritt 8 Install the new battery
Connect the new battery before seating it if its flex cable isn't pre-folded.
Use the connected flex cable to guide the battery into position without straining it.
Press the battery onto the double-sided adhesive so it stays in place.
Schritt 9 Secure the battery connector
Lift the battery connector enough to place the small contact back in position.
Use tweezers to install the small contact near the battery connector.
Press the battery connector back onto its socket.
Align the screw holes in the connector area.
Use a Phillips screwdriver to reinstall the two screws near the battery connector.
Schritt 10 Reinstall the rear case
Set the rear case a few millimeters above its fully closed position.
Slide the rear case downward until it seats.
Use a pentalobe screwdriver or T5 Torx screwdriver to reinstall the two bottom screws.
Tighten the bottom screws until they are seated.
Schritt 11 Test charging and startup
Connect the iPhone to the charging cable or charging station.
Wait for the iPhone to boot.
Watch for the charging current to rise into the normal range.
Confirm the battery percentage rises after a short charge.
Schritt 12 Check the removed battery
Use a battery charging station to test or recharge the removed battery if you have one.
Disconnect the iPhone; the charging station should return to 0 A with nothing connected.
Connect the removed battery to the iPhone 4S port on the battery charging station.
Watch whether the current stabilizes, because a bad contact may cause unstable readings.
Test the removed battery in another phone if you need confirmation and can do so safely.
Schritt 13 Choose a reliable battery
Use a replacement battery that is known to work with the exact iPhone model.
If the bootloop remains and current still drops to 0 A, troubleshoot logic board faults.
If the iPhone boots and charging current stays near the normal range, let the new battery charge before regular use. Recycle the old battery through a battery recycler. Repair didn't go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Eine weitere Person hat diese Anleitung absolviert.
