Zum Hauptinhalt wechseln
Lenovo IdeaPad 3-15IIL05 SSD Replacement
Was du brauchst
  1. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Prepare your laptop for disassembly: Schritt 1, Bild 1 von 2 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Prepare your laptop for disassembly: Schritt 1, Bild 2 von 2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Unfasten the back cover: Schritt 2, Bild 1 von 2 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Unfasten the back cover: Schritt 2, Bild 2 von 2
    • Use a Phillips screwdriver to remove the ten screws securing the back cover:
    • Six 7.6 mm-long screws
    • Four 4.7 mm-long screws
  3. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Insert an opening pick: Schritt 3, Bild 1 von 3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Insert an opening pick: Schritt 3, Bild 2 von 3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Insert an opening pick: Schritt 3, Bild 3 von 3
    • Plastic clips secure the back cover to the frame. You'll hear and feel the clips release.
    • Insert the flat side of an opening pick between the top left corner of the back cover and frame.
    • Angle the pick down to about 45 degrees.
  4. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the left clips: Schritt 4, Bild 1 von 3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the left clips: Schritt 4, Bild 2 von 3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the left clips: Schritt 4, Bild 3 von 3
    • Keep the opening pick angled down at about 45 degrees while sliding it along the front and side edges to help release the clips.
    • Slide the pick to the bottom left corner of the laptop to release the left clips.
  5. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the bottom clips: Schritt 5, Bild 1 von 3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the bottom clips: Schritt 5, Bild 2 von 3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the bottom clips: Schritt 5, Bild 3 von 3
    • Slide the opening pick to the bottom right corner to release the bottom clips.
  6. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the right clips: Schritt 6, Bild 1 von 3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the right clips: Schritt 6, Bild 2 von 3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the right clips: Schritt 6, Bild 3 von 3
    • Slide the opening pick to the top right corner to release the right clips.
  7. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Insert an opening pick: Schritt 7, Bild 1 von 2 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Insert an opening pick: Schritt 7, Bild 2 von 2
    • Insert the flat end of an opening pick between the back cover and frame, to the left of the right hinge.
    • Pry the back cover up with the pick to release the top right clips.
    • Leave the pick inserted next to the right hinge.
  8. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the top clips: Schritt 8, Bild 1 von 3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the top clips: Schritt 8, Bild 2 von 3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Release the top clips: Schritt 8, Bild 3 von 3
    • Angle the pick up to about 45 degrees.
    • Slide the opening pick to the top left corner to release the remaining clips.
  9. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Remove the back cover: Schritt 9, Bild 1 von 3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Remove the back cover: Schritt 9, Bild 2 von 3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Remove the back cover: Schritt 9, Bild 3 von 3
    • Remove the back cover.
    • During reassembly, lay the back cover on the frame and press firmly around the perimeter to engage all the clips.
  10. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Disconnect the battery: Schritt 10, Bild 1 von 3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Disconnect the battery: Schritt 10, Bild 2 von 3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Disconnect the battery: Schritt 10, Bild 3 von 3
    • Use the flat end of a spudger to gently push the battery connector out of its socket on the motherboard.
  11. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Remove the thermal pad: Schritt 11, Bild 1 von 3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Remove the thermal pad: Schritt 11, Bild 2 von 3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Remove the thermal pad: Schritt 11, Bild 3 von 3
    • A delicate thermal pad covers the SSD. If you're planning on reusing it, be extra careful during this step.
    • Gently lift the left edge of the thermal pad.
    • Carefully slide the flat end of a spudger back and forth under the pad while slowly peeling the pad back.
    • Remove the thermal pad.
    • Set the thermal pad aside and apply it to the new SSD during reassembly.
    • If you tore the thermal pad when taking it off, don’t worry—you can still reuse it.
  12. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Unfasten the SSD: Schritt 12, Bild 1 von 2 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Unfasten the SSD: Schritt 12, Bild 2 von 2
    • Use a Phillips screwdriver to remove the 3 mm-long screw securing the SSD.
    • The SSD will pop up at a slight angle with the screw removed.
  13. Lenovo IdeaPad 3-15IIL05 SSD Replacement, Remove the SSD: Schritt 13, Bild 1 von 3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Remove the SSD: Schritt 13, Bild 2 von 3 Lenovo IdeaPad 3-15IIL05 SSD Replacement, Remove the SSD: Schritt 13, Bild 3 von 3
    • Pull the SSD out of its socket and remove it.
    • During reassembly, insert the SSD at a slight downward angle into its socket.
Abschluss
Check your repair by running hardware tests with Lenovo Diagnostics.
Spencer Day
54.795 Reputation
407 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
17.271 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 54
Letzte 30 Tage: 320
Insgesamt: 1,485
