Zum Hauptinhalt wechseln
Lenovo Ideapad 320-15IAP Battery Replacement
Was du brauchst
  1. Lenovo Ideapad 320-15IAP Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Lenovo Ideapad 320-15IAP Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #0 screwdriver, unscrew all thirteen 6.5 mm screws from the back case.
  2. Lenovo Ideapad 320-15IAP Battery Replacement: Schritt 2, Bild 1 von 1
    • Pull the CD drive outwards with an opening tool until it pops out as shown. It is possible you have to apply a substantial amount of force so watch your fingers while doing so.
    • Remove the CD drive.
  3. Lenovo Ideapad 320-15IAP Battery Replacement: Schritt 3, Bild 1 von 1
    • Lift up the cover using the opening tool on different spots along the side of the laptop.
  4. Lenovo Ideapad 320-15IAP Battery Replacement: Schritt 4, Bild 1 von 2 Lenovo Ideapad 320-15IAP Battery Replacement: Schritt 4, Bild 2 von 2
    • Using a Phillips #0 screwdriver to unscrew the four 5.5 mm screws securing the battery.
  5. Lenovo Ideapad 320-15IAP Battery Replacement: Schritt 5, Bild 1 von 2 Lenovo Ideapad 320-15IAP Battery Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  6. Lenovo Ideapad 320-15IAP Battery Replacement: Schritt 6, Bild 1 von 1
    • Remove the battery.
Abschluss
For optimal performance, after completing this guide, calibrate your newly installed battery.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 45
Insgesamt: 1,092
