Einleitung
Use this guide to replace the smart card reader in a Lenovo ThinkPad T460.
The smart card reader’s job is to read a smart card, which is a device used to store data and provide login authentication.
If you cannot retrieve data or log in to your laptop using a smart card, or if you are experiencing error messages when using a smart card, you may need to replace your laptop’s smart card reader.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Was du brauchst
Place the laptop so that the bottom is facing upwards.
Slide the latch on the left side of the battery to the left until it clicks in place.
Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
Use your other hand to slide the battery towards the back of the laptop.
Lift the battery up and away from the laptop.
Loosen the eight captive screws in the bottom cover using a Phillips #1 screwdriver.
Insert the flat end of a spudger in between the bottom cover and the rest of the laptop, starting in the lower left corner.
Pry the lower left corner of the bottom cover up by a few millimeters.
Slide the spudger along the bottom of the laptop to release the clips until you reach the lower right corner.
Slide the spudger along the right and top sides of the bottom cover to release the clips.
Use the spudger to pry the upper left corner up by a few millimeters.
Pry up the sections of the bottom cover with printed logos of the ports.
Use the spudger to pry up the bottom cover in the lower portion of the external battery compartment by a few millimeters.
Remove the three 3.7 mm screws from the internal battery using a Phillips #1 screwdriver.
Remove two 5 mm screws from the speaker in the lower right-hand corner using a Phillips #1 screwdriver.
Use your fingers to lift the black flap up from the smart card reader cable connector.
Use the pointed end of a spudger to open the white clip on the smart card reader connector.
Remove two 3.8 mm screws from the smart card reader bracket using a Phillips #1 screwdriver.
Use your fingers to lift the smart card reader bracket up and away from the laptop.
Remove two 3.7 mm screws from the smart card reader using a Phillips #1 screwdriver.
Use the flat end of a spudger to pry the smart card reader up by a few millimeters.
Use your other hand to lift the smart card reader up and away from the laptop.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
