Zum Hauptinhalt wechseln
Lenovo ThinkPad T480s Hall Sensor Replacement
Was du brauchst
  1. Lenovo ThinkPad T480s Hall Sensor Replacement, Bottom Cover: Schritt 1, Bild 1 von 2 Lenovo ThinkPad T480s Hall Sensor Replacement, Bottom Cover: Schritt 1, Bild 2 von 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Hall Sensor Replacement: Schritt 2, Bild 1 von 3 Lenovo ThinkPad T480s Hall Sensor Replacement: Schritt 2, Bild 2 von 3 Lenovo ThinkPad T480s Hall Sensor Replacement: Schritt 2, Bild 3 von 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Hall Sensor Replacement: Schritt 3, Bild 1 von 2 Lenovo ThinkPad T480s Hall Sensor Replacement: Schritt 3, Bild 2 von 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Hall Sensor Replacement, Battery: Schritt 4, Bild 1 von 2 Lenovo ThinkPad T480s Hall Sensor Replacement, Battery: Schritt 4, Bild 2 von 2
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s Hall Sensor Replacement: Schritt 5, Bild 1 von 3 Lenovo ThinkPad T480s Hall Sensor Replacement: Schritt 5, Bild 2 von 3 Lenovo ThinkPad T480s Hall Sensor Replacement: Schritt 5, Bild 3 von 3
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: Schritt 6, Bild 1 von 3 Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: Schritt 6, Bild 2 von 3 Lenovo ThinkPad T480s Hall Sensor Replacement, Hall Sensor: Schritt 6, Bild 3 von 3
    • Use a spudger to disconnect the cable from the Hall sensor.
  7. Lenovo ThinkPad T480s Hall Sensor Replacement: Schritt 7, Bild 1 von 2 Lenovo ThinkPad T480s Hall Sensor Replacement: Schritt 7, Bild 2 von 2
    • With the Phillips #1 screwdriver, remove one 3.1 mm screw from the sensor.
  8. Lenovo ThinkPad T480s Hall Sensor Replacement: Schritt 8, Bild 1 von 3 Lenovo ThinkPad T480s Hall Sensor Replacement: Schritt 8, Bild 2 von 3 Lenovo ThinkPad T480s Hall Sensor Replacement: Schritt 8, Bild 3 von 3
    • Remove the sensor from the system.
Abschluss
Sarah Westberg
23.465 Reputation
70 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
137 Mitglieder
17.524 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 111
Insgesamt: 2,450
