Zum Hauptinhalt wechseln
Lenovo ThinkPad T480s Speaker Replacement
Was du brauchst
  1. Lenovo ThinkPad T480s Speaker Replacement, Bottom Cover: Schritt 1, Bild 1 von 2 Lenovo ThinkPad T480s Speaker Replacement, Bottom Cover: Schritt 1, Bild 2 von 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Speaker Replacement: Schritt 2, Bild 1 von 3 Lenovo ThinkPad T480s Speaker Replacement: Schritt 2, Bild 2 von 3 Lenovo ThinkPad T480s Speaker Replacement: Schritt 2, Bild 3 von 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Speaker Replacement: Schritt 3, Bild 1 von 2 Lenovo ThinkPad T480s Speaker Replacement: Schritt 3, Bild 2 von 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Speaker Replacement, Battery: Schritt 4, Bild 1 von 2 Lenovo ThinkPad T480s Speaker Replacement, Battery: Schritt 4, Bild 2 von 2
    • Use the Phillips #1 screwdriver to remove four 4.5mm screws that hold the battery down to the mid frame.
  5. Lenovo ThinkPad T480s Speaker Replacement: Schritt 5, Bild 1 von 3 Lenovo ThinkPad T480s Speaker Replacement: Schritt 5, Bild 2 von 3 Lenovo ThinkPad T480s Speaker Replacement: Schritt 5, Bild 3 von 3
    • Lift the battery near the connector and remove it from the system.
  6. Lenovo ThinkPad T480s Speaker Replacement, Speaker: Schritt 6, Bild 1 von 3 Lenovo ThinkPad T480s Speaker Replacement, Speaker: Schritt 6, Bild 2 von 3 Lenovo ThinkPad T480s Speaker Replacement, Speaker: Schritt 6, Bild 3 von 3
    • Disconnect the speaker cable from the motherboard using a connector puller or spudger.
  7. Lenovo ThinkPad T480s Speaker Replacement: Schritt 7, Bild 1 von 2 Lenovo ThinkPad T480s Speaker Replacement: Schritt 7, Bild 2 von 2
    • Using a Phillips #1 screwdriver, remove two 4.8 mm screws from the speaker on the right side.
  8. Lenovo ThinkPad T480s Speaker Replacement: Schritt 8, Bild 1 von 3 Lenovo ThinkPad T480s Speaker Replacement: Schritt 8, Bild 2 von 3 Lenovo ThinkPad T480s Speaker Replacement: Schritt 8, Bild 3 von 3
    • Using a Phillips #1 screwdriver, remove two 4.8 mm screws from the speaker on the left side.
  9. Lenovo ThinkPad T480s Speaker Replacement: Schritt 9, Bild 1 von 3 Lenovo ThinkPad T480s Speaker Replacement: Schritt 9, Bild 2 von 3 Lenovo ThinkPad T480s Speaker Replacement: Schritt 9, Bild 3 von 3
    • Use the spudger to disconnect the hall sensor connector.
  10. Lenovo ThinkPad T480s Speaker Replacement: Schritt 10, Bild 1 von 3 Lenovo ThinkPad T480s Speaker Replacement: Schritt 10, Bild 2 von 3 Lenovo ThinkPad T480s Speaker Replacement: Schritt 10, Bild 3 von 3
    • Lift the speakers up.
    • Disconnect the cable speakers from the routing.
    • Remove the speakers from the system.
Abschluss
Sarah Westberg
23.348 Reputation
70 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.420 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 50
Insgesamt: 1,355
