Zum Hauptinhalt wechseln
Lenovo ThinkPad T480s Wi-Fi Card Replacement
Was du brauchst
  1. Lenovo ThinkPad T480s Wi-Fi Card Replacement, Bottom Cover: Schritt 1, Bild 1 von 2 Lenovo ThinkPad T480s Wi-Fi Card Replacement, Bottom Cover: Schritt 1, Bild 2 von 2
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
  2. Lenovo ThinkPad T480s Wi-Fi Card Replacement: Schritt 2, Bild 1 von 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement: Schritt 2, Bild 2 von 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement: Schritt 2, Bild 3 von 3
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Wi-Fi Card Replacement: Schritt 3, Bild 1 von 2 Lenovo ThinkPad T480s Wi-Fi Card Replacement: Schritt 3, Bild 2 von 2
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Wi-Fi Card Replacement, Wi-Fi Card: Schritt 4, Bild 1 von 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement, Wi-Fi Card: Schritt 4, Bild 2 von 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement, Wi-Fi Card: Schritt 4, Bild 3 von 3
    • Using the nylon spudger, pop the coaxial antenna wires off the Wi-Fi card.
    • When reassembling, reattach the gray wire closest to the screw and the black wire on the other side of the gray wire.
  5. Lenovo ThinkPad T480s Wi-Fi Card Replacement: Schritt 5, Bild 1 von 2 Lenovo ThinkPad T480s Wi-Fi Card Replacement: Schritt 5, Bild 2 von 2
    • Use the Phillips #1 screwdriver to remove one 2.8mm screw holding the Wi-Fi card down to the motherboard.
  6. Lenovo ThinkPad T480s Wi-Fi Card Replacement: Schritt 6, Bild 1 von 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement: Schritt 6, Bild 2 von 3 Lenovo ThinkPad T480s Wi-Fi Card Replacement: Schritt 6, Bild 3 von 3
    • Slide the Wi-Fi card out from the slot.
Abschluss
Sarah Westberg
23.194 Reputation
70 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
17.146 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 29
Letzte 30 Tage: 123
Insgesamt: 1,882
