Zum Hauptinhalt wechseln
MSI GE62 Apache Pro 004 Web Camera Replacement
Was du brauchst
  1. MSI GE62 Apache Pro 004 Web Camera Replacement, Battery: Schritt 1, Bild 1 von 1
    • Start with the bottom of the laptop facing up.
    Frag FixBot
    Kommentar hinzufügen
  2. MSI GE62 Apache Pro 004 Web Camera Replacement: Schritt 2, Bild 1 von 2 MSI GE62 Apache Pro 004 Web Camera Replacement: Schritt 2, Bild 2 von 2
    • Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
    • Remove the bottom plate by pulling away from laptop
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go
    Frag FixBot
  3. MSI GE62 Apache Pro 004 Web Camera Replacement: Schritt 3, Bild 1 von 3 MSI GE62 Apache Pro 004 Web Camera Replacement: Schritt 3, Bild 2 von 3 MSI GE62 Apache Pro 004 Web Camera Replacement: Schritt 3, Bild 3 von 3
    • Remove the screw holding down the battery with a PH1 screwdriver.
    • Pull out the battery.
    Frag FixBot
  4. MSI GE62 Apache Pro 004 Web Camera Replacement, Web Camera: Schritt 4, Bild 1 von 1
    • Flip over the laptop and open it.
    Frag FixBot
  5. MSI GE62 Apache Pro 004 Web Camera Replacement: Schritt 5, Bild 1 von 3 MSI GE62 Apache Pro 004 Web Camera Replacement: Schritt 5, Bild 2 von 3 MSI GE62 Apache Pro 004 Web Camera Replacement: Schritt 5, Bild 3 von 3
    • Slide a metal opener tool along the outside edges of the front screen panel to start to separate it from the back screen panel.
    • You may need to apply some firm pressure to get it started.
    Frag FixBot
  6. MSI GE62 Apache Pro 004 Web Camera Replacement: Schritt 6, Bild 1 von 2 MSI GE62 Apache Pro 004 Web Camera Replacement: Schritt 6, Bild 2 von 2
    • Once it has started to separate, gently pull off the screen panel by working along the edge, and set it aside.
    • Do not force off. Front screen panel is thing and can break or crack very easily.
    Frag FixBot
  7. MSI GE62 Apache Pro 004 Web Camera Replacement: Schritt 7, Bild 1 von 2 MSI GE62 Apache Pro 004 Web Camera Replacement: Schritt 7, Bild 2 von 2
    • Locate the WebCam on the middle of the device.
    • Slide a metal opener tool to remove the Webcam
    Frag FixBot
Abschluss
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
USF Tampa, Team S15-G5, Boczar Spring 2018 Mitglied von USF Tampa, Team S15-G5, Boczar Spring 2018
USFT-BOCZAR-S18S15G5
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 26
Insgesamt: 1,200
