Einleitung
This guide will help you replace the battery in your MSI GS63VR 6RF Stealth Pro. You will need to have purchased the replacement battery prior if you are replacing your battery.
Was du brauchst
Use a Phillips screwdriver to remove the 15 screws securing the back cover.
Insert an opening tool or spudger in the seam and pry along the perimeter to loosen the back cover.
Remove the back cover.
For optimal performance, after completing this guide, calibrate your newly installed battery.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
