MacBook 13.3" LCD Panel
  • MacBook 13.3" LCD Panel
Glossy finish screen. LCD is new and in excellent condition.
The part you receive may or may not have the screw holes on top of the LCD. You can still use the part even though you do not use those screws.
49,99 $
49,99 $
Wir senden dir eine E-Mail, sobald der Artikel wieder verfügbar ist.
Artikelbeschreibung
Beschreibung
Beschreibung
Replace your cracked or damaged MacBook LCD with this part. This part is compatible with all 13.3" (1280x800) MacBooks (excluding MacBook Unibody and MacBook Air).
Hinweis
This part does not include the backlight inverter and is not compatible with any MacBook Unibody, Pro, or Air models.
Kompatibilität
MacBook Core 2 Duo
1.83 GHz
2 GHz (Early 2009)
2 GHz (Late 2006)
2 GHz (Mid 2007)
2 GHz (Santa Rosa)
2.1 GHz (Penryn)
2.13 GHz (Mid 2009)
2.16 GHz
2.2 GHz (Santa Rosa)
2.4 GHz (Penryn)
MacBook Core Duo
1.83 GHz
2 GHz
Reparatur-Geschichten
public1's Story Photo #344437
public1's Story Photo #344439
Mein Problem
We gave my old MacBook to my father-in-law's caregiver so she could work on some language courses and connect to some safety monitors. But it turned out that my optical drive had gotten flaky since I'd last used it and I already knew that the screen had a vertical bar with a different intensity, pr . . .
Adam Cox's Story Photo #318482
Adam Cox's Story Photo #318483
Mein Problem
I was asked to fix a backlight issue on a 2008 13" black MacBook Penryn by a client. The screen was showing, but the backlight wouldn't turn on and would only flicker when you played with the F1 & F2 keys.
Meine Reparatur
I tried replacing the display inverter first, but that only worked for about an hour. That's wh . . .
Mein Problem
Because I could not see half of my screen.
Meine Reparatur
It Was painless with the ifix.com it guide.
Mein Rat
Take your time and be careful with the housing for the keyboard connector super easy to damage!!
Mein Problem
I had my wife's Macbook with us on vacation. We travelled in a van through Australia. One time I accidentally stepped on the Macbook which was underneath a pile of clothes. The only thing that was broken was the LCD screen. A serious area contained dead black pixels.
I ordered recently a new . . .
Mein Problem
The screen in the MacBook (Early 2009) had no light. First I changed the inverter and inverter cable but still no light. So I decided to change the LCD panel as well and this did the trick.
Meine Reparatur
I followed the guide to change the LCD panel and had no big problems.
Mein Rat
Invest in proper tools! Screwdrivers and . . .
Mein Problem
My dear lappy's screen has been broken for three years. I've had a PC monitor hooked to it, effectively making it the world's only desk-bound laptop. Frankintosh still ran well, though. I had to do something.
Meine Reparatur
"Oh, this is pretty easy, doot doot doo. I mean, if I can do this without--what the !&&* is . . .
Mein Problem
Older macbook, but still a nice computer. After being dropped there were several cracks obscuring the display.
Meine Reparatur
I used the "long" technique completely removing the display from the laptop. It took me 2 hours to complete the disassembly and 90 minutes to put it back together again. The instructions wer . . .
Mein Problem
Cracked screen
Meine Reparatur
Done. Easy!
Mein Rat
Patience.
Mein Problem
My 4 year old son decided to be rough with the MacBook closing the lid one night.
Meine Reparatur
One order from you and 2.5 hours later the screen was replaced. Your guides rock.
Mein Rat
Set aside 2.5 to 3 hours to do this job completely.
Mein Problem
The backlight on my wife's MacBook Core 2 Duo was burned out - the computer turned on and worked well when plugged in to an external display, but the built-in display did not turn on. Actually, it did - as you could see the image on screen from a certain angle, but the backlight was not working. I h . . .
Mehr anzeigen
