Zum Hauptinhalt wechseln
« Zurück zu allen Geschichten
20 disoriented magnets
Josh Yacktman -
Giiker Super Slide
Bild zur Geschichte
  • Bild #1
  • Bild #2
Giiker Super Slide Teardown
2 Stunden
Moderate
Mein Problem
When making the teardown of the Giiker Super Slide, I hadn't realized that there was an extra screw holding in the back shell. While trying to find out what was holding it on, I suddenly heard a lot of magnets moving inside. When I found and removed the final screw I found that none of the screws had been adhered to the shell and that they had all come out of their sockets with no common orientation
Meine Reparatur
It went well, I was able to reorient the magnets and test that they were all oriented properly. The device works fine upon reassembly and I am back to happily solving my puzzles
Mein Rat
If you have one set of magnets, you likely have another set they were meant to attach to. Using this second set, you can get the proper orientation of the loose magnets you have in your scenario. In my case I took a magnetic piece, put it in the play area tray, and inserted magnets if they did not resist one pair at a time until all were inserted
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 372
