Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Apple Watch Series 3 zu reparieren, verwende unsere Fehlerbehebungsseite.
    1. Apple Watch Series 3 Teardown, Apple Watch Series 3 Teardown: Schritt 1, Bild 1 von 1
      • What's that in your shiny new Apple Watch?
      • Second-generation OLED Retina display with Force Touch
      • Consistent with the original Apple Watch, the Series 3 comes in two sizes: 38 mm (272 × 340 pixels, 290 ppi) and 42 mm (312 × 390 pixels, 302 ppi).
      • Custom-designed Apple S3 SiP (System in Package)
      • Optional LTE and UMTS, built in GPS/GLONASS + NFC + Wi-Fi 802.11b/g/n 2.4 GHz + Bluetooth 4.2
      • Accelerometer + gyroscope + heart rate sensor + microphone + speaker + barometric altimeter + ambient light sensor
      • Water resistance rating (up to 50 meters)
      • WatchOS 4
      Frag FixBot
      Kommentar hinzufügen
    2. Apple Watch Series 3 Teardown: Schritt 2, Bild 1 von 2 Apple Watch Series 3 Teardown: Schritt 2, Bild 2 von 2
      • Before we get inside, put on your X-ray glasses for a sneak peek.
      • Many Bothans died to bring us this information. Just kidding. This image is courtesy of the friendly X-ray experts at Creative Electron.
      • While the overall layout is fairly unchanged from the original Apple Watch we tore down and X-rayed in 2015, it looks like there may be a few extra solder pads under the speaker (top right of this image).
      Frag FixBot
    3. Apple Watch Series 3 Teardown: Schritt 3, Bild 1 von 3 Apple Watch Series 3 Teardown: Schritt 3, Bild 2 von 3 Apple Watch Series 3 Teardown: Schritt 3, Bild 3 von 3
      • Time for a quick check of the back to make sure we bought the right watch.
      • Yep, this here is an Apple Watch Series 3, the most exclusive and top of the line Apple wrist computer, offering unparalleled computing power and fashion for the next 51 weeks.
      • We even got the LTE model!
      • Next to that secret diagnostic port we picked out a new model number: A1889.
      Frag FixBot
    4. Apple Watch Series 3 Teardown: Schritt 4, Bild 1 von 3 Apple Watch Series 3 Teardown: Schritt 4, Bild 2 von 3 Apple Watch Series 3 Teardown: Schritt 4, Bild 3 von 3
      In diesem Schritt verwendetes Werkzeug:
      iOpener
      $24.95
      Frag FixBot
    5. Apple Watch Series 3 Teardown: Schritt 5, Bild 1 von 2 Apple Watch Series 3 Teardown: Schritt 5, Bild 2 von 2
      • Cables de-ZIF'd, we're clear to get a look at the display.
      • Spec-wise, the display is unchanged from the Series 2, with one key difference—it now functions as a multifrequency (LTE?) antenna.
      • We'll be testing compatibility to see if the displays really are interchangeable.
      • This display has one fewer IC than last year. Probably wasn't important.
      • Analog Devices 343S00092 touch controller
      • NXP Semiconductor PN80V NFC module
      • Texas Instruments TPS36372 display power management (likely)
      • Empty solder pad (20211CP TD1628A goes here?)
      Frag FixBot
    6. Apple Watch Series 3 Teardown: Schritt 6, Bild 1 von 3 Apple Watch Series 3 Teardown: Schritt 6, Bild 2 von 3 Apple Watch Series 3 Teardown: Schritt 6, Bild 3 von 3
      Mako Driver Kit - 64 Precision Bits
      $39.95
      • As in the prior version, further access is barred by a tiny tri-point screw—one of 64 possible contingencies we've come prepared for.
      • The top third of the watch is labeled "Taptic Engine," and that's mostly true—but the label also hides a bracket that guards, among other things, the battery connector we're searching for.
      • Time to pick away the power pack and see what gives this watch its all-day go-juice.
      • Professional teardown engineer on a closed track. Do not attempt battery replacement on the go.
      Frag FixBot
    7. Apple Watch Series 3 Teardown: Schritt 7, Bild 1 von 2 Apple Watch Series 3 Teardown: Schritt 7, Bild 2 von 2
      Frag FixBot
    8. Apple Watch Series 3 Teardown: Schritt 8, Bild 1 von 3 Apple Watch Series 3 Teardown: Schritt 8, Bild 2 von 3 Apple Watch Series 3 Teardown: Schritt 8, Bild 3 von 3
      • So far so good. We pull out the standard Force Touch sensor/gasket, equipped with the same Analog Devices AD7149 capacitance sensor controller that we found in the Series 2.
      • Continuing our parts-picking spree, we pluck out the Taptic Engine, seemingly unchanged from watches yore.
      • Then out pops the antenna array, including what we believe to be the GPS antenna.
      Frag FixBot
    9. Apple Watch Series 3 Teardown: Schritt 9, Bild 1 von 3 Apple Watch Series 3 Teardown: Schritt 9, Bild 2 von 3 Apple Watch Series 3 Teardown: Schritt 9, Bild 3 von 3
      • The plucking continues, as we remove the self-emptying speaker, designed to sonically blast out water after your watch takes a dip.
      • After an entirely Series 2-ish experience, we're finally rewarded with something new—a whole new section of RF chips, surely responsible for handling the added LTE functionality.
      • In another new twist, the air vent hole next to the microphone is now populated by what looks like a barometric pressure sensor.
      • Apple touted a new barometric altimeter when it introduced the Series 3 at the Steve Jobs Theater—much to our confusion, since we already found a barometer in last year's model.
      • Time to pull this board!
      Frag FixBot
    10. Apple Watch Series 3 Teardown: Schritt 10, Bild 1 von 2 Apple Watch Series 3 Teardown: Schritt 10, Bild 2 von 2
      Frag FixBot
    11. Apple Watch Series 3 Teardown: Schritt 11, Bild 1 von 3 Apple Watch Series 3 Teardown: Schritt 11, Bild 2 von 3 Apple Watch Series 3 Teardown: Schritt 11, Bild 3 von 3
      • Last call: back cover. It's press-fit over a teflon-like O-ring, but a thumbs-up and a firm push relieves it of duty.
      • The material has been standardized across watch models and souped up to snazzy ceramic, replacing the previous Ion-X or Sapphire options.
      • It also houses the PPG sensor array that is responsible for sensing heart rate.
      • It would've been cool to see some change from the Series 2 after complaints about accuracy in previous models. As far as wearables go, however, the Apple Watch is the best of the bad.
      • Also it appears that the wireless charging coil has been slightly modified to support most Qi wireless chargers.
      • Lastly, with the new barometric altimeter taking the spot next to the microphone, where did the air vent go? Answer: hiding out right here, next to the diagnostic port.
      Frag FixBot
    12. Apple Watch Series 3 Teardown: Schritt 12, Bild 1 von 3 Apple Watch Series 3 Teardown: Schritt 12, Bild 2 von 3 Apple Watch Series 3 Teardown: Schritt 12, Bild 3 von 3
      • Here's all the clockwork watchwork!
      • Final big thanks to Circuitwise for giving up a bit of their weekend to help us out!
      • And thanks again to Creative Electron for putting the X(-ray) in "excellent!"
      Frag FixBot
    13. Fazit
      • Watch band replacements remain fast and simple.
      • Screen replacements are difficult but do-able—it's the first thing to come off, and detaches via simple ZIF connectors.
      • Battery replacements are tricky but fairly straightforward once you're inside, provided you're armed with a Y000 screwdriver.
      • While not proprietary, incredibly tiny tri-point screws are a repair hinderance.
      • Replacing any of the component cables requires microsoldering.
      • The mostly resin-encased S3 system makes most board-level repairs impossible.
      Reparierbarkeits-Index
      6
      Reparierbarkeit 6 von 10
      (10 ist am einfachsten zu reparieren)
47 Kommentare zur Anleitung
Great ! I was waiting for this since the day it was shown at the launch ! First to comment as well I guess
Yolo - Antwort Teilen
is the rear housing the same as the series 2 as well?
during the announcement, they claimed the watch was made a little thicker.
karl - Antwort Teilen
What’s the purpose of the air vent that began with Series 2? It’s clearly not for barometric readings since Series 2 lacked a barometric altimeter.
Andrew Estock - Antwort Teilen
Not sure of I didn't See a barometer at the Apple Watch
eisblock - Antwort Teilen
does apple tv 4k teardown coming soon? i am curious about power supply voltage and ampere. nice btw.
Muhammad Faisal Kemal - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 14
Letzte 7 Tage: 83
Letzte 30 Tage: 369
Insgesamt: 260,951
