Zum Hauptinhalt wechseln
Was du brauchst
Einführungsvideo
Dieser Teardown ist keine Reparaturanleitung. Um dein PlayStation 4 Pro zu reparieren, verwende unsere Fehlerbehebungsseite.
    1. PlayStation 4 Pro Teardown, PlayStation 4 Pro Teardown: Schritt 1, Bild 1 von 3 PlayStation 4 Pro Teardown, PlayStation 4 Pro Teardown: Schritt 1, Bild 2 von 3 PlayStation 4 Pro Teardown, PlayStation 4 Pro Teardown: Schritt 1, Bild 3 von 3
      • Since this is the third version of the PS4, maybe we should call it the PS4 3? Anyways, here are the specs:
      • 8-core AMD "Jaguar" X86-64 CPU, clocked at 2.1 GHz (up from 1.6 GHz)
      • 4.2 TFLOPS AMD Radeon-based graphics
      • 8 GB GDDR5 RAM + 1 GB DRAM
      • 1 TB removable and upgradeable hard drive storage
      • 802.11 a/b/g/n/ac, Ethernet, and Bluetooth 4.0 (LE)
      • Blu-ray × 6 CAV, DVD × 8 CAV
      Frag FixBot
      Kommentar hinzufügen
    2. PlayStation 4 Pro Teardown: Schritt 2, Bild 1 von 2 PlayStation 4 Pro Teardown: Schritt 2, Bild 2 von 2
      • Hamburger, meet Big Mac—the Pro version has one layer on the Slim version. It's also quite a bit bigger overall.
      • This behemoth still carries the label PlayStation 4, but the model number on ours is CUH-7015B. We also spot a couple "Warranty void if removed stickers" (booo) and tons of different ports (yay!):
      • Power
      • HDMI 2.0
      • PlayStation extension port
      • S/PDIF optical audio output
      • USB 3.0
      • Ethernet
      Frag FixBot
    3. PlayStation 4 Pro Teardown: Schritt 3, Bild 1 von 3 PlayStation 4 Pro Teardown: Schritt 3, Bild 2 von 3 PlayStation 4 Pro Teardown: Schritt 3, Bild 3 von 3
      • When you're exploring unknown territory, it helps to have a map.
      • We called up our buddies at Creative Electron, and they put their X-ray vision to good use.
      • So far we're expecting to find... bees? And a big fan. I'm not the only one who sees honeycomb, right?
      Frag FixBot
    4. PlayStation 4 Pro Teardown: Schritt 4, Bild 1 von 3 PlayStation 4 Pro Teardown: Schritt 4, Bild 2 von 3 PlayStation 4 Pro Teardown: Schritt 4, Bild 3 von 3
      • This triple-decker design is a little different from the ''first'' fourth PlayStation we tore down, but that doesn't stop our teardown engineers—without wasting time, we flip the console over, pop the first panel, and hit pay dirt!
      • A single, standard Phillips #0 screw stands between us and hard-drive-swapping glory. Now that's what I'm talkin' 'bout.
      • Replacements are awesome, and in keeping with a long tradition: every PlayStation to use a hard drive has had a user-replaceable hard drive.
      • Like the original PlayStation 3
      • ... and the Slim
      • ... and the Super Slim
      • ... right up to the original PlayStation 4 and PlayStation 4 Slim.
      Frag FixBot
    5. PlayStation 4 Pro Teardown: Schritt 5, Bild 1 von 1
      • And just a couple more Phillips screws later, the 2.5" HGST HTS541010A9E680 hard drive is free from its caddy shackles.
      • While the PlayStation team boasted about the Pro's SATA III support, this stock hard disk drive is rated at 3.0 Gb/s (SATA II).
      • Or is it? According to various online sources, this guy is actually a 6.0 Gb/s HDD. Regardless, at 5400 RPM this platter drive will never reach SATA III speeds and is pretty similar to the drive we found in 2013.
      • No worries, though—armed with the right tools and some elbow grease (and a snazzy new 6.0 Gb/s SSD), you can cut your lag load times in half and get back to gaming.
      Frag FixBot
    6. PlayStation 4 Pro Teardown: Schritt 6, Bild 1 von 3 PlayStation 4 Pro Teardown: Schritt 6, Bild 2 von 3 PlayStation 4 Pro Teardown: Schritt 6, Bild 3 von 3
      In diesem Schritt verwendetes Werkzeug:
      Mako Driver Kit - 64 Precision Bits
      $39.95
      • As expected, we're gonna have to remove these "Warranty void if seal removed" stickers to go any further.
      • Adding a bit of insult to injury, the screws hidden beneath are Security Torx screws—specifically designed to stop you getting in.
      • Luckily, even the most dastardly screw head is no match for our 64 Bit Driver Kit. With the case cracked open, we can remove this large metal shield.
      • Unfortunately, all this does is give us a view of the motherboard's backside.
      • Based on our experience with the PS4 Slim, we decide to flip everything over and see if the grass is any greener on the other side...
      Frag FixBot
    7. PlayStation 4 Pro Teardown: Schritt 7, Bild 1 von 2 PlayStation 4 Pro Teardown: Schritt 7, Bild 2 von 2
      • With the beast on its back, the opposite panel pops off after some prodigious prying—but no "warranty void" stickers!
      • Alas, removing this panel isn't the panel-cea we were hoping for. We can pull out the power supply, but nothing else.
      • While you can't remove the fan, you could certainly clean it from here—maybe that's why we're granted this non-warranty-voiding access zone.
      Frag FixBot
    8. PlayStation 4 Pro Teardown: Schritt 8, Bild 1 von 3 PlayStation 4 Pro Teardown: Schritt 8, Bild 2 von 3 PlayStation 4 Pro Teardown: Schritt 8, Bild 3 von 3
      • With the top panel removed, we focus our attention towards the power supply unit.
      • Unlike the 2013 model, which topped out at 165 W, this PSU dishes out 289 W of power (1.5 A @ 4.8 V +23.5 A @ 12 V).
      • According to the official technical specifications, the PS4 Pro pulls 310 W of power total. The balance is probably spent in transforming power from AC to DC.
      • And now for the million dollar question: Why is this console so much bigger than the original?
      • For comparison purposes, we lined up the PSU from the PS4 Pro (left) and the original PS4 (right). While there's only an 74.2 g difference between the two units, the requisite heat pipe and fan add a bit more bulk to the Pro to wick away excess heat generated by the additional graphics power.
      Frag FixBot
    9. PlayStation 4 Pro Teardown: Schritt 9, Bild 1 von 3 PlayStation 4 Pro Teardown: Schritt 9, Bild 2 von 3 PlayStation 4 Pro Teardown: Schritt 9, Bild 3 von 3
      • Thwarted by the lack of any more screw heads on the PSU-side of the PS4 Pro, we flip it back over and flip our attention to the the motherboard.
      • Burrowing through a layer of shielding behind the CPU reveals this cool X-shaped retaining bracket, similar to ones we found in another console.
      • And directly underneath it, we dig up a plastic-and-metal cover that looks to be the consumer electronics version of a pizza saver, protecting the back of the board from the heat sink retaining bracket.
      • Lifting the motherboard reveals a lot more thermal management. Highlights include a giant copper heat sink and dedicated pads for six chips on the motherboard.
      Frag FixBot
    10. PlayStation 4 Pro Teardown: Schritt 10, Bild 1 von 1
      • Let's take a closer look at the front side of the motherboard:
      • SCEI (Sony Computer Entertainment, Inc.) CXD90044G SoC (includes AMD "Jaguar" Cores and AMD Radeon GPU)
      • Panasonic MN864729 HDMI transmitter
      • Samsung K4B4G0846E-BYK0 512 MB DDR3 SDRAM
      • Sony/Renesas R9J04G011FP1 I/O controller (likely)
      • Infineon (formerly International Rectifier) IR35218 PWM controller
      • Fairchild Semiconductor FDMF6840C 50 A power stage
      • Cypress CYUSB3312 USB 3.0 hub controller
      Frag FixBot
    11. PlayStation 4 Pro Teardown: Schritt 11, Bild 1 von 1
      • And bringing up the rear:
      • 8 x Samsung K4G80325FB-HC28 8 GB GDDR5 (1 GB × 8 = 8 GB)
      • Sony J20H091 Wireless Communication module (Marvell Avastar 88W8897 underneath)
      • SCEI (Sony Computer Entertainment, Inc.) CXD90036G I/O controller (likely)
      • This is a Custom ASIC on Marvell's 88EC128-BNS2
      • Samsung K4B4G0846E-HC28 512 MB DDR3 RAM
      • Rohm BD7764MUV motor controller
      • Rohm BD9685 synchronous step-down switching regulator
      Frag FixBot
    12. PlayStation 4 Pro Teardown: Schritt 12, Bild 1 von 2 PlayStation 4 Pro Teardown: Schritt 12, Bild 2 von 2
      • IC Identification, continued:
      • Sony A02-C0L2 secure microcontroller (likely)
      • Macronix MX25L25635FZ2I-10G 256 MB serial flash memory
      • ON Semiconductor CAT24C128WI−GT3 128 KB serial EEPROM memory
      • Richtek RT5069A power management
      • Texas Instruments TLV62090 3 A step-down converter
      • Richtek RT8237F synchronous buck PWM controller
      • Texas Instruments SN74AUC2G66 2-channel SPST analog switch
      Frag FixBot
    13. PlayStation 4 Pro Teardown: Schritt 13, Bild 1 von 3 PlayStation 4 Pro Teardown: Schritt 13, Bild 2 von 3 PlayStation 4 Pro Teardown: Schritt 13, Bild 3 von 3
      • The fan and optical drive seem almost within reach—and yet they're screwed in from the bottom, where a large heat pipe assembly keeps guard. However, we're not scared.
      • Okay, we lied—we're a little scared.
      • We manage to extract the heat pipe gear without serious injury, clearing our way to that spinny thing that blows air.
      • This Nidec fan is rated for 2.1 amps at 12 volts, or 25.2 watts. So that's where all that extra PSU power is going...
      Frag FixBot
    14. PlayStation 4 Pro Teardown: Schritt 14, Bild 1 von 3 PlayStation 4 Pro Teardown: Schritt 14, Bild 2 von 3 PlayStation 4 Pro Teardown: Schritt 14, Bild 3 von 3
      • We pluck out the optical drive, claw-game style.
      • We do some more clawing (and unscrewing) to get this beast open. We find:
      • A lot of springs.
      • A lens assembly on a track, with some sweet stabilization action.
      • And some sweet gears.
      Frag FixBot
      • The optical drive's laser pickup assembly is ready for its closeup.
      • Remember to deactivate your lasers before poking them.
      • We use a little compressed air to move the pickup arm. It's super responsive and likely does a great job with skip protection.
      • Handy for gaming while 'froadin, or while living in California.
      Frag FixBot
    15. PlayStation 4 Pro Teardown: Schritt 16, Bild 1 von 3 PlayStation 4 Pro Teardown: Schritt 16, Bild 2 von 3 PlayStation 4 Pro Teardown: Schritt 16, Bild 3 von 3
      • With some determined prying, we remove this triple-decker PS4's middle tier. Turns out it's just a plastic frame, which we quickly pull away, revealing a final component or two.
      • This LED light guide catches light from the LEDs on the left-hand board, and also serves as the button covers for the mechanical switches on the two right-hand boards.
      Frag FixBot
    16. PlayStation 4 Pro Teardown: Schritt 17, Bild 1 von 2 PlayStation 4 Pro Teardown: Schritt 17, Bild 2 von 2
      • PlayStation 4 Pro, deftly disassembled.
      • Miss the PS4 Slim teardown? Check out our speedrun video teardown on YouTube.
      • And because we love you, here's a bonus X-ray image of the PS4 Pro controller.
      Frag FixBot
    17. Fazit
      • No adhesive makes disassembly and reassembly easy.
      • The non-proprietary hard drive is simple to access and upgrade/replace—and doing so will not void your warranty.
      • While you can freely clean the fan, removing it—and other components—requires lots of (warranty-voiding) disassembly.
      • Security screws and tamper-evident seals discourage users from disassembling and repairing their PS4.
      Reparierbarkeits-Index
      8
      Reparierbarkeit 8 von 10
      (10 ist am einfachsten zu reparieren)
75 Kommentare zur Anleitung
Can anyone confirm if the GPU in this Pro is actually a Radeon RX 480 put together with the Jaguar cores?
Kenneth Rodriguez - Antwort Teilen
Its got 2304 cores so same as RX 480 but seeing as how they need to maintain compatibility id say the shaders aren't true GCN 4 like the 480 but still GCN1.1 like the original PS4.
Owen10578 - Antwort Teilen
i just bought a ps4 here in japan. i just want to know if can i use it in 220volts? thanks
nick - Antwort Teilen
Is the PS4 pro power supply a dual voltage
dejinas - Antwort Teilen
Yes. When you zoom-in left picture in step 8, it says 100-240
TeaMu - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 104
Letzte 7 Tage: 649
Letzte 30 Tage: 2,857
Insgesamt: 520,743
