Einleitung
We’re on a mission to tear down all the Galaxy Things that Samsung released at Unpacked this month. Beans? All chewed up. Watch? All wound down. Next on the teardown table: the Galaxy Note 20 and 20 Ultra. It’s a side-by-side teardown-athon that we won’t be doing twice, so grab your S-Pen and follow along as we scribble out these Notes.
For more teardowns than you can swing a stylus at, follow us on Twitter, Instagram, and Facebook. For iFixit delivered, check out our newsletter.
Was du brauchst
Einführungsvideo
There are multiple versions of both these phones in circulation—but we opted for US models with 5G mmWave to bring you the most complete-est teardown for your money. Our specs include:
Snapdragon 865+ processors paired with 8 GB (Note 20) or 12 GB (Ultra) of LPDDR5
Infinity-O AMOLED displays—6.7" (2400 × 1080) on the Note 20, and 6.9" (3088 × 1440) on the Ultra with 120 Hz refresh rate
128 GB of internal storage, plus up to an extra 1 TB on the Ultra via microSD
Four cameras each, including a 10 MP selfie and 12 MP ultra-wide. The vanilla Note 20 also gets a 12 MP wide-angle and a 64 MP telephoto, while the Ultra packs a 108 MP wide-angle and a 12 MP periscope telephoto with 5x optical zoom
Batteries: 4300 mAh in the Note 20, and 4500 mAh in the Ultra
5G and Ultra Wide Band connectivity, plus 4x4 MIMO LTE, 802.11ax Wi-Fi, and BT 5.0
One important spec we left out: colors! We opted for Mystic Green on the Note 20, and Mystic Bronze on the Ultra. Why? Because there was no Mystic Blue and Black option.
For instance, why are the wireless charging coils—those concentric rings in the middle of each phone—so different? Samsung hasn't hinted at any major spec differences, but the Ultra has an intriguing double-coil configuration.
It's also striking how much extra real estate the Ultra devotes to its camera modules. That 108 MP peeper in the middle is already enormous, and that's before Samsung throws in the sliding periscope module right next to it.
First things first, we use our S Pens to jot down a few notes about camera bumps. If you like your glass to have glass sticking out of it, the Galaxy Note 20 Ultra is the phone for you.
That sprawling triple-lens bump in the iPhone 11 Pro Max now seems like the height of restraint. We are officially sorry for all our complaints.
Google may be the smartphone maker to most convincingly buck this trend, by doing more with less—replacing physical hardware with bleeding-edge software whizbangery. Samsung's approach here is pretty cool, but we'll be keeping our peepers open for the Pixel 5.
can you tell me how much does the camera module protude?
good evening I have a note 20 ultra 5g and following a fall of not even 50 centimeters the screen is cracked knowing that I buy it in its sealed box
In diesem Schritt verwendetes Werkzeug:iSclack$24.99
With that, we go to work. Our iOpener was nearly rendered irrelevant by the heat wave here on the west coast—we probably could've just left both phones outside for a spell to soften the adhesive.
You can debate in the comments whether a $1,000 phone should be clothed in plastic, but repairability-wise, it's probably a net win.
Next, some careful iSclack and opening pick action—and both back covers lift free cleanly, without booby-traps. This teardown is officially underway.
In diesem Schritt verwendetes Werkzeug:Essential Electronics Toolkit$29.95
As with most phones, the screws are the first to go once we're inside. And our Essential Electronics Toolkit is here, ready and waiting to take them out.
A few extremely tight midframe screws later, here's our first good look inside (in the visible-light spectrum, anyway).
Each phone gets its earpiece speaker mounted to the upper antenna assembly, which contains a dedicated speaker enclosure—that's a first! The speaker is the rectangular bit framed with a bright red gasket. It still fires through a channel in the midframe, much like it did on the Note10 and S20—but the new larger enclosures ought to boost audio quality a bit.
Both phones also get a rear-facing mic that piggybacks directly onto the back cover. Thankfully they connect via repair-friendly spring contacts, which is why we didn't encounter any booby traps opening these things up.
Next up: cameras. Both motherboards have to come out first.
The Ultra inherits the super-cool optical Space Zoom module from the S20 Ultra, but with a smaller 12 MP sensor behind it. (Click the link for a detailed take-apart of the periscope mechanism.) The regular Note 20 doesn't "space zoom," instead relying on a dense 64 MP sensor and some cropping magic.
The situation reverses for the wide-angle module, where the Ultra gets a gigantic 108 MP sensor—which, like the S20 Ultra, usually bins down to 12 MP. Meanwhile, the regular Note packs a more modest 12 MP sensor here.
Neither Note gets the S20 Ultra's 40 MP front-facing camera—instead, both pack 10 MP selfie sensors, which appear to come bundled with some unfortunate smoothing effects.
Thank you, Samsung, for making these motherboards look like AT-ATs. We expect a battle to break out on Hoth any minute now! Here's what these transports are carrying:
Snapdragon 865+ layered under Samsung LPDDR5 RAM
Samsung KLUDG4UHDB 128 GB universal flash storage
Qualcomm SDX55M 5G modem-RF system and SMR526 intermediate frequency IC
Qualcomm QDM4820, QDM5872, and QDM4870 FEMs
NXP 11OUV2H and 9468B3, likely a part of NXP's "industry-first solution to combine UWB fine-ranging, NFC, Secure Element, and embedded SIM"
Maxim MAX77705C PMIC
Likely ON Semiconductor FPF3788UCX OVP load switch
They've turned around and are now fighting for the rebellion!
Qualcomm SDR865 5G and LTE transceiver
Likely Wacom W9020 digitizer controller
Murata 1RH WiFi + Bluetooth module
Skyworks SKY77365 power amplifier module
Qualcomm PMX55, PM150C, and PM8250 power management ICs
AVAGO AFEM-9136 front-end modules
Qualcomm QPA5580 power amplifier module
What's worse than removing a glued-down Note battery? Removing two of them ... at the same time.
Luckily we've got our adhesive remover handy. A few squirts, some patience, and a little persuasion from a pair of suction cups helps us safely remove both batteries without breaking too much of a sweat.
By this point, it feels inevitable that Samsung batteries will always be glued in like this, but we're not ready to give up hope yet. Samsung, if you're listening, there's a better way. (And prior to that, there was an even better-er way.)
These Note 20 and Note 20 Ultra juice packs weigh in at 16.69 and 17.46 watt-hours, respectively.
Both beat the 15.04 Wh pack in the iPhone 11 Pro Max, but fall behind the 19.30 Wh monster in the S20 Ultra—which didn't have to make room for a stylus, therefore moar battery.
The strangest thing about these phones so far is, of all things, what lies underneath the motherboards.
Stranger still, it seems some other Note 20 phones do have copper heat pipes—but not our US-spec model. Does the Exynos SoC on international models require different cooling hardware than our phones, with their Snapdragon processors?
Our friend Zack, of JerryRigEverything fame, tells us his South Korea model also has graphite. Stay tuned for more details on that.
Our next thought was, maybe this comes down to heat-prone 5G mmWave hardware, which not all Notes have—but that doesn't line up either. Is it some kind of A/B test on new cooling hardware? There must be some logic here, but we can't figure it out. Let us know if you have ideas.
Speaking of mmWave modules—both our phones have them, but only two each. In contrast, the Note10+ 5G and S20 Ultra got three. Has the hardware improved such that only two are needed, or is something else going on?
Last to leave their metal home are the two AMOLED displays. And behind them is some of that copper we were looking for!
Samsung has long lined their displays with copper to help disperse heat—and that's still the case here, despite the switch to the graphite underneath the motherboard.
Both these phones share the code name Canvas. Not quite as clever as last year's Davinci, but apt nonetheless.
The back side of each display hosts an integrated ultrasonic fingerprint sensor. Meanwhile, Corning's new Gorilla Glass Victus protects the front—promising "significant improvement in both drop and scratch performance, for the first time ever in the Gorilla Glass family."
We're almost done—but if you need one last look, here's the Ultra being bombarded with X-rays from every angle.
One thing we failed to locate in our teardown: Ultra Wide Band antennas, like we found in the iPhone 11 series. Did we somehow miss it, or is Samsung's implementation completely different?
I’m upgrading from a Note 8 to the Note 20 Ultra, black. Upgrading because my Note 8 caught a little sun and the battery swelled, but the phone still worked perfectly, even during charging. Love this phone and think it’s well worth the price since I’m a bit of a tech head and love all the stuff the phone comes with. You guys take care.
That's all she Note!
User Space Saga posted our favorite: Samsung didn't intentionally put the number 20 to this year's Note series—It was just a typo, but before anyone noticed, the leaks had already begun.
Congrats! You won yourself a pair of super-repairable Galaxy Beans. (Why didn't that name stick?)
As always, we leave you with the repairability score—a fitting note on which to end, wouldn't you agree?
- You'll only need one screwdriver, a standard Phillips.
- Many components are modular and can be replaced independently, including the charge port.
- Battery replacement remains far too difficult for a consumable component.
- Screen repairs are tedious, poorly prioritized, and unnecessarily expensive.
- All repairs demand battling through tough adhesive, then painstakingly cleaning and replacing it.
Fazit
Reparierbarkeits-Index
(10 ist am einfachsten zu reparieren)
25 Kommentare
yet this guy tears it down quickly and has little trouble with the adhesive using the proper solvent :)
It’s just isopropyl alcohol, and unfortunately it doesn’t help all that much. You can see from the video how tedious it is. Now try doing that after a year, when the adhesive has hardened, and the back glass is shattered. And then try putting it back together with fresh adhesive afterward. Nobody is saying it’s impossible, but this phone’s 3/10 repairability score is well earned.
Anyone know what kind of adhesive is used?
I would expecting to see that the instructor would ware ESD strap , remove the Sim tray before losing any screws and then to cover the cameras with tape protector and keep away from finger prints.
Good luck
How is the camera bump sealed to the rear glass?
What sd card does this support LOL. Does it have the second row of pins for UHS-2?
No, I don’t think the the SD card slot has the second row of pins for UHS-II. UHS-II card is usable but runs at UHS-II speed.
Don't see any mention of the haptic motors, and whether Samsung has gimped the regular Note 20 as well?
Buds Contest:
Well, There was a Note 10+, quickly followed by the “Note 10+ Max” , which tended to blow up whenever you accessed Google! . I believe there also was a “10+ Max Ultra”(Which was huge!) prototype. but the original designs were destroyed in an arson event allegedly, attributed to an industrial espionage incident, again allegedly, attributed to having been caused by ex Apple employees. By the time all of these variants were sorted out , it was already the beginning of 2018! A guy in marketing came up with “S19/Note19” but, it was nixed! 2020 has some significance in the Chinese calendar (I know, Korea?!?) and it was just around the corner so, …. Taa Daa!!
everyone knows the REAL reason for the samsung note going from 10 to 20 is simply because apple patented the numbers 11-19 in order to thwart samsung’s progress of the note series! :)
Is the Note 20 5G version screen the same as the regular version?
Hi, I don't know if you read this. I have Exynos Note 20 Ultra, by mistake I poked the upper microphone hole adjacent to the SIM hole when I was trying to eject my SIM cards. Now, I'm worried about the phone’s IP rating. Is it compromised? I don't know if I poked too hard. I did the *#0283# microphone test and it came good. All three mics gave feedbacks.
everything is ok, this should not be a problem (hole has 90 deg turn so you cannot damage the membrane)
artur -
i just finished replacing the LCD screen for my note 20 ultra (it cracked from the top of the up volume key to the hole on the top frame almost precisely from a very minor drop only 3 weeks into owning it) and i cant help but feel that this was one of the easiest screen replacements i’ve ever had to to do. ok, the rear glass is a pain to remove and you need to exercise patience however, once inside after removing a bunch of screws that, beside three near the charging port are identical, every phone component inside popped out beautifully and they were substantial in nature making it easy to remember where they came from, what order they came out in and pretty hard to misplace / lose. for the battery i just laid the phone, broken screen down on at 90 deg C heat mat for a couple of mins and the battery came off with relative ease. yeah, one of the easiest almost foolproof screen replacements i’ve ever done. i have to add that a heat pad made a big difference in controlling how much heat was applied.
hello Paul M - would you be able to make a guide for this? so just to change the glass (right? not the oled itself) you had to burrow from the back all the way to the screen? I have a note 20 ultra with less then an inch long microcracks at the right edge (from bottom edge of power button to the top edge of the top volume button) Touch etc all fine no issues with the display Thanks
s ner -
Buenas tardes, Un Note 20 ltra, despues de cambiar la logica, sigue conservando la IP68?
hi i would like to know how the mic holes get the water proofing seals? ive read the other comments about poking the upper mic by mistake. i also did it. ive seen live tear down and i was looking for a hole on the top mic from the inside of the phone on your video. im just curious where did they put the seal to water proof it? i did poke the top mic by mistake but i went in REALLY hard. i have been searching around the internet bout the water proofing seals and where did they placed it. is it on top of the 90 degree curve? or the bottom?
what is circled in the image I've linked to?
I went to a water park and the phone was soaked in water. I left it in the rice container for 3 days out in the sun and it finally booted up. The phone was in airplane mode, no wifi, no network. I did a reboot and still nothing. When i ejected SIM tray it said no SIM found but when i put it back in, no network or wifi. I tried to reset wifi and network several times but didn't help. I cannot do a factory reset because it says i needed wifi. At this point im guessing these 2 features are on 1 component and it got damaged somehow. What part do i order so i can swap out and bring my phone back to life? Thank you
Hi ifixit, My phone Samsung Galaxy Note 20 Ultra 5G and a charging port failure after replacing it still won't take charge in (Wireless charger works). Is it because of the failure in bottom board that control mic and bottom speaker. I need help regarding the failure in the cable charging system. The power supply work perfectly fine no issue with it.
¿Cuando sacas la tapa trasera, que es el la pieza que va pegada a la parte del cristal de la cámara que además conecta en la parte delantera del móvil?
