Von Studierenden verfasstes Wiki
Ein tolles Team von Studierenden aus unserem Bildungsprogramm hat dieses Wiki erstellt.
Computer Will Not Power On
When pressing the power button, computer does not respond or turn on.
Damaged Power Adapter(Charger)
After plugging the AC adapter into the AC port a light at the bottom left corner of the laptop should display either a white light indicating laptop is fully charged, an orange light indicating its charging at the moment, or a flashing orange light indicating very low battery and it should be left unused so it can charge quicker. If none of these indications occurs it means your adapter is broken.
Faulty Battery
Check to see if battery is secured and locked in place. Plug in the AC adapter(charger) then turn on the laptop. After the laptop turns on unplug the AC adapter. If laptop shuts off right away upon removing adapter it is indicative of a faulty battery and the battery may need to be replaced. Click here to see the replacement guide for the replacing the battery.
Computer Won't Boot
Your computer does not load the Operating System and instead takes you to an error message.
Hard Drive Error
Your computer enter an endless cycle of resetting without entering the usual home screen. If a blue screen with intricate error codes appears it may be necessary to replace the hard drive.
Replace Hard Drive
If the device is experiencing a loop which resets the device then automatically turning it back on there may be an issue with the hard drive. After a couple of loops a blue screen will appear displaying some error message. This is known as "Blue Screen of Death". This blue screen is a sign that your hard drive could be corrupted and need to be replace. Click here for a guide on how to replace your hard drive.
Not Enough RAM
In some cases a blue error screen may be the result of faulty RAM storage. Overusing the device memory can lead to the crashing of certain programs, or even a complete system crash. A possible solution would be to check the amount of memory being used at the time and make sure that it is not exceeding the amount your RAM is able to handle.
Connectivity Issues
Laptop having trouble connecting to WiFi/ unable to read WiFi signals.
Check Router Connection
Check your router box and see if the WiFi display light is on, if not reset your router by either finding the reset button for your router and press it or unplug the main power cord of your router and re plugging it.
Check WiFi Setting
On the home screen a WiFi icon is on the bottom right corner. Click on the WiFi icon and locate your unique WiFi display name. Click on the WiFi icon associated with the network connection and enter your WiFi password. The WiFi password may be located on WiFi router.
Outdated Drivers
Make sure that your WiFi is turned by placing the cursor on the WiFi icon on laptop display screen. If Wi-Fi is already on and the computer cannot properly connect to Wi-Fi go to the Lenovo website and download the appropriate driver for the correct operating system.
No Display
Your device won't load onto your desktop home screen.
Force Restart
Hold the power button for 10 second to make sure your system is completely shut down. Let the laptop sit for about 5-10 minutes before turning it back on. Sometimes this can solve the problem due to software issues causing the laptop to freeze up.
Damaged Screen
If screen is noticeably damaged or is unreadable to to discoloration then the screen needs to be replaced. Click here for a guide to replace your damage/broken screen.
Failure to Read CD's and DVD's
Your Lenovo IdeaPad 110-15IBR will not read any CD's or DVD's.
Disk is Scratched
Before you proceed to replacing optical drive check to see If the disc you inserted is noticeably scratched consider replacing the disc as this could be the reason the disc will not play.
Broken/Defective Optical Drive
If your Lenovo IdeaPad 110-15IBR optical drive does not open or does not read CD's or DVD's, the optical drive may be broken and needs to be replaced.
31 Kommentare
My LENOVO IDEAPAD-110 Battery reading right not show please informed me
shahmdmobassir - Antwort Teilen
Lots of awesome answers here but none to fix my problem
- my laptop is a Lenovo 110 ideapad
- my laptop powers on straight away to show the boot menu and no matter what you click it will continue to show this
- I entered the BIOS menu and it wasn't reading my hard drive
- took the back off and took out the hard drive and put it back in - rechecked and it has been recognised by my laptop
- however the problem still occurs with it opening straight to boot menu
please help!! ((Amij15@hotmail.com)) if you think you can help me i’d really appreciate it.
Ami - Antwort Teilen
Mine started the same today
Wanice Matthews-Sprouse - Antwort Teilen
is problem solved?
Mithun Parmar - Antwort Teilen
my lenovo idea pad 110-141BR web cam is not responding it says to go in manufacture website and trouble shoot
Abishek Poudel - Antwort Teilen
