Zum Hauptinhalt wechseln
Lenovo Yoga 910-13IKB Battery Replacement
Was du brauchst
  1. Lenovo Yoga 910-13IKB Battery Replacement, Back Panel: Schritt 1, Bild 1 von 2 Lenovo Yoga 910-13IKB Battery Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel using the T5 Torx Screwdriver.
    • Remove the back panel from the device exposing the components.
  2. Lenovo Yoga 910-13IKB Battery Replacement, Battery: Schritt 2, Bild 1 von 1
    • Remove the four 3 mm Phillips #0 screws holding the battery in place.
  3. Lenovo Yoga 910-13IKB Battery Replacement: Schritt 3, Bild 1 von 3 Lenovo Yoga 910-13IKB Battery Replacement: Schritt 3, Bild 2 von 3 Lenovo Yoga 910-13IKB Battery Replacement: Schritt 3, Bild 3 von 3
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery. The spudger tool may be needed to lift the flap seal.
    • Pull parallel to the battery, not straight up.
    • Pull evenly on the width of the cable so that no individual wire is overly strained.
    • Lift the battery out.
Abschluss
For optimal performance, after completing this guide, calibrate your newly installed battery.
9 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team S1-G5, White Winter 2020 Mitglied von Cal Poly, Team S1-G5, White Winter 2020
CPSU-WHITE-W20S1G5
4 Mitglieder
14 Anleitungen geschrieben
4 Kommentare
Step 3-6 are redundant to simply change the battery, correct?
oslodave - Antwort
You're right! I fixed the guide to reflect this.
Arthur Shi -
Maybe I haven't seen many battery connectors, but this is one of the most annoying to reinsert.
Noah - Antwort
Easy battery replacement on Yoga 910. The repair kit contains a variety of small repair tools and is very nice for the price. Found some small metallic discs when disassembled; they were spacers for the screws in the back casing and superglued them back to the casing before reassembly.
InfamousB - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 40
Letzte 30 Tage: 197
Insgesamt: 10,254
