Zum Hauptinhalt wechseln
Microsoft Surface Laptop 3 15" LCD Panel Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Koreanisch
Schritt 7
Microsoft Surface Laptop 3 15" LCD Panel Replacement, Soften the left edge adhesive: Schritt 0, Bild 1 von 3 Microsoft Surface Laptop 3 15" LCD Panel Replacement, Soften the left edge adhesive: Schritt 0, Bild 2 von 3 Microsoft Surface Laptop 3 15" LCD Panel Replacement, Soften the left edge adhesive: Schritt 0, Bild 3 von 3
  • The adhesive securing the screen to the back cover is very strong and requires a lot of heat before you can create an initial gap.
  • Note the location of the adhesive we're softening on this step: long strips secure each short edge of the screen.
  • Apply a heated iOpener to the left edge of the screen for three minutes.
  • Alternatively, use a heat gun or hair dryer to soften the adhesive. If you're reusing your screen, be careful not to overheat it. Heat it enough so you can barely touch it comfortably.
Hier Übersetzung einfügen
