Zum Hauptinhalt wechseln
Nintendo 3DS XL 2015 Hauptplatine austauschen
Hinweis: Du bearbeitest gerade eine grundständige Anleitung, die Teil der Anleitung ist, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 8 Anleitungen, die diese grundständige Anleitung beinhalten.
Englisch
Deutsch
Schritt 9
Nintendo 3DS XL 2015 Motherboard Replacement: Schritt 0, Bild 1 von 3 Nintendo 3DS XL 2015 Motherboard Replacement: Schritt 0, Bild 2 von 3 Nintendo 3DS XL 2015 Motherboard Replacement: Schritt 0, Bild 3 von 3
  • Using tweezers, gently pull the four marked ribbons out of the ZIF connectors along the sides of the motherboard.
  • These ZIF connectors are held in place by friction and do not have locks—lifting the flaps on these connectors will break them!
  • Three of the ribbon connectors have plastic clamping flaps that cover the ribbon to prevent slippage. Use the tweezers to flip them up before ribbon removal.
  • This one ribbon connector may also have a plastic clamping flap, but it's not like the others, rather it's similar to the one used for the Circle Pad. Gently flip up the flap on the side opposite the ribbon cable to remove the cable.
  • This connector was previously listed among the ones that do not have locks, however on most if not all systems, it actually does have one. Trying to remove or reinsert this cable without unlocking it will damage the cable, requiring a replacement of the Touch Screen's digitizer. Fortunately, the LCD uses other ZIF connectors, so that should still be fine.
  • If, on your system, this connector does not have a lock after all, do not pull up on the flap! It should come up easily; if it doesn't, it probably isn't meant to lock, but instead just hold the cable in with friction. In that case, try gently pulling the cable out of the connector.
  • When reassembling the device, be sure to flip the ZIF clamps back down.
  • While the SD card reader is shown as removed in this photo, it is optional for the removal of the motherboard.
Löse mit der Pinzette vorsichtig die fünf markierten ZIF Verbinder auf der Hauptplatine.
Vorsicht! Diese ZIF Verbinder werden nur eingeklemmt und haben keine Sicherungsbügel. Wenn du die Klappen daran hochhebst, wirst du sie abbrechen. Es kann aber auch sein, dass der oberste Verbinder eine Sicherung hat.
Drei Verbinder haben einen Sicherungsbügel. Klappe ihn hoch und löse die Verbindung.
[* yellow] Dieser Flachbandverbinder kann eine Kunststoffklappe haben, die jedoch anders aussieht. Sie ähnelt der Klappe vom Schiebepad. Um das Kabel zu entfernen, hebe die Klappe auf der gegenüberliegenden Seite des Flachbandkabels vorsichtig nach oben.
Denke beim Zusammenbau daran, die ZIF Bügel wieder zu befestigen.
Auf dem Foto ist der SD Kartenleser entfernt. Das kannst du machen, unbedingt nötig ist es aber nicht.
