Einleitung
你Apple Watch里的电池坏掉了或是鼓包了吗?跟着我们的指南来更换一个新的电池。
提醒:如果你的电池鼓包了, 您需要采取适当的预防措施。
Was du brauchst
准备一个 iOpener (或者拿一个电吹风机或热风枪),将加热过的 iOpener 放在表的正面,直到它摸起来稍微有点烫。
将你的 iOpener 留在上面至少一分钟,使得屏幕充分受热并软化粘合剂。
用剪刀将你的塑料撬片剪到大概和电池一样宽。尽量不要有锋利的边角。
从电池和边框的右侧缝隙插入剪过的塑料撬片。
缓慢地使用均匀的力将电池撬起,把它与将其固定到主板上的粘合剂分离。
较大的型号(42毫米)存在意外将电池底下的主板撬到的可能性。请只将塑料撬片深入足够的长度来达到电池下部,不要触及主板。
必要时在电池周围和底部使用高纯度酒精(90%或更高)来帮助减弱教授随的粘性。
想要将你的设备重新装好,请从第17步开始按照Force Touch传感器指南来重新组装你的手表并且完成修理。
362 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
30 Kommentare
I did a battery replacement in a 38mm Series 1 iwatch and the darn battery is not charging properly. It's been on the charger about 3 hours and I'm only at 14%. Any suggestions?
I managed to replace a swollen battery ($33.25 on amazon) that popped the screen, but this is not for the faint of heart. Special emphasis needs to be placed on not twisting the digitizer connectors as they are quite fragile ($119.99 on ebay for a new digitizer). It's also easy to damage the force-touch sensor ($24.95 on iFixit). You also need adhesive gaskets ($12.98 for 5 on Amazon)
iFixit lists all the parts required but were out of stock on all but one of the items I needed at the time.
Battery:
https://www.amazon.com/gp/product/B01MV2...
Digitizer:
http://www.ebay.com/itm/262744629522?_tr...
Force Touch Sensor Gasket:
[verlinktes Produkt fehlt oder ist deaktiviert: IF308-013-2]
Adhesive Strips:
Appreciate the detailed steps, happy for the option but after reading the $79 to get Apple to replace vs the $33, plus tools for battery... taking it to Apple Store does not seem so bad.
79 is just for battery …there Will be around 220$ service fees extra !!!
Nope $79 complete. Just had it done at Apple store. Took about 30 minutes.
Albert -
