Einleitung
If your battery is worn or defective, this guide will show you how to replace your battery. The battery is located internally in the laptop and requires removal of the keyboard module for access.
Was du brauchst
Use a Philips #1 screwdriver to remove the nine screws from the back cover.
Turn the laptop over and open the display.
Insert the flat edge of the spudger into the crease of the keyboard cover.
While the spudger is in the crease, carefully pry open the casing by sliding the spudger along the edge.
Slowly lift the cover open from the front of the laptop, but do not completely remove it.
Note the locations of the three white and blue data cables connecting to the keyboard to the computer's main board.
Remove the two screws securing the battery to the laptop case with a Phillips #1 screwdriver.
Lift the battery out and remove it:
Use your fingertips to evenly grip the battery on the left and right sides of the battery.
Pull straight up to lift the battery out of its place.
For optimal performance, after completing this guide, calibrate your newly installed battery.
10 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
No need to disconnect the ribbon cables to gain access to the battery. Gently move keyboard toward you to expose the battery.
Very nice and well explained! Bravo! Easy steps! Congratulations! :-)
