Zum Hauptinhalt wechseln
Backbone One Left Bumper Replacement
Was du brauchst
  1. Backbone One Left Bumper Replacement, Unfasten the screws: Schritt 1, Bild 1 von 1
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
    Frag FixBot
    Kommentar hinzufügen
  2. Backbone One Left Bumper Replacement, Rotate the upper cover: Schritt 2, Bild 1 von 3 Backbone One Left Bumper Replacement, Rotate the upper cover: Schritt 2, Bild 2 von 3 Backbone One Left Bumper Replacement, Rotate the upper cover: Schritt 2, Bild 3 von 3
    • Lift up the upper part of the controller.
    • Swing over the upper cover and place it on the controller case.
    • Take care that the interconnecting cable has no tension.
    Frag FixBot
  3. Backbone One Left Bumper Replacement, Remove the protective tape: Schritt 3, Bild 1 von 3 Backbone One Left Bumper Replacement, Remove the protective tape: Schritt 3, Bild 2 von 3 Backbone One Left Bumper Replacement, Remove the protective tape: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable connector.
    Frag FixBot
  4. Backbone One Left Bumper Replacement, Open the ZIF connector: Schritt 4, Bild 1 von 2 Backbone One Left Bumper Replacement, Open the ZIF connector: Schritt 4, Bild 2 von 2
    • Use the tip of an opening pick to open the gray flap of the ZIF connector by pushing it upwards.
    Frag FixBot
  5. Backbone One Left Bumper Replacement, Disconnect the interconnect cable: Schritt 5, Bild 1 von 2 Backbone One Left Bumper Replacement, Disconnect the interconnect cable: Schritt 5, Bild 2 von 2
    • Use your fingers to disconnect the interconnect cable from its connector.
    Frag FixBot
  6. Backbone One Left Bumper Replacement: Schritt 6, Bild 1 von 2 Backbone One Left Bumper Replacement: Schritt 6, Bild 2 von 2
    • Remove the upper half of the left controller assembly.
    Frag FixBot
  7. Backbone One Left Bumper Replacement, Remove the screw: Schritt 7, Bild 1 von 2 Backbone One Left Bumper Replacement, Remove the screw: Schritt 7, Bild 2 von 2
    • Use a Phillips screwdriver to remove the 5.9 mm-long screw which is securing the trigger.
    • The screw is difficult to reach. Insert the screwdriver at an angle of 45 degrees.
    Frag FixBot
  8. Backbone One Left Bumper Replacement, Remove the trigger: Schritt 8, Bild 1 von 2 Backbone One Left Bumper Replacement, Remove the trigger: Schritt 8, Bild 2 von 2
    • Remove the left trigger.
    Frag FixBot
  9. Backbone One Left Bumper Replacement, Remove the bumper: Schritt 9, Bild 1 von 2 Backbone One Left Bumper Replacement, Remove the bumper: Schritt 9, Bild 2 von 2
    • Use your fingers to remove the left bumper.
    Frag FixBot
Abschluss
iFixit Mitglied von iFixit
Staff
122 Mitglieder
25.813 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 16
Letzte 30 Tage: 55
Insgesamt: 1,368
