Einleitung
You'll find that this will help improve your battery life to factory new! Always be careful when working with a battery.
Was du brauchst
Use tweezers to pry and remove the center screw cover on the back cover.
Use a Phillips screwdriver to unscrew the nine 6.8 mm screws securing the back cover.
Use a spudger to pry around the base edges of the back cover to loosen it from the laptop.
Unlock the wide ZIF connector securing the flex cable.
Pull the ribbon cable outwards to disconnect the back cover from the motherboard.
Use a Phillips screwdriver to unscrew the three 4 mm screws securing the battery.
Use your fingers (or a set of tweezers) to disconnect the battery cable from the motherboard by gently pulling it towards the battery.
Lift and remove the battery from its recess.
For optimal performance, after completing this guide, calibrate your newly installed battery.
6 weitere Personen haben diese Anleitung absolviert.
