Einleitung
Use this guide to remove and replace the lower case on a Dell XPS 17 9710.
The edges of the lower case are very sharp and can easily cut you. Avoid sliding your fingers along the edge of the lower case.
Was du brauchst
Power off and unplug your laptop.
Close the display and flip the entire laptop upside-down, with the hinge facing away from you.
Use a Torx T5 screwdriver to remove the eight 4.4 mm-long screws that secure the lower case.
Insert an opening pick at the bottom left corner, between the lower case and the chassis.
Insert the flat end of a spudger into the gap created by the opening pick.
Pivot the spudger up to release the first set of retaining clips.
Repeat this process for the bottom right corner.
Insert an opening pick into the gap created on the front edge of the laptop.
Slide the opening pick around the entire perimeter of the laptop, prying up intermittently, until the lower case fully releases from the clips on the chassis.
Lift the lower case up and off of the chassis to remove it.
Eine weitere Person hat diese Anleitung absolviert.
