Zum Hauptinhalt wechseln
HTC Vive XR Elite Depth Sensor Replacement
Was du brauchst
  1. HTC Vive XR Elite Depth Sensor Replacement, Prepare your Vive XR Elite for disassembly: Schritt 1, Bild 1 von 1
    • Before starting this repair, discharge the batteries in your headset below 25%. A charged battery may leak dangerous chemicals or catch fire if damaged.
    • Playing Half Life: Alyx will do the trick!
    • The Vive XR Elite has a proximity sensor that puts the headset in standby mode to save battery when it isn't in use. To drain the battery faster you'll need to use the headset.
  2. HTC Vive XR Elite Depth Sensor Replacement, Disconnect the USB-C power cable: Schritt 2, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Disconnect the USB-C power cable: Schritt 2, Bild 2 von 2
    • Disconnect the USB-C power cable.
  3. HTC Vive XR Elite Depth Sensor Replacement, Disconnect the battery cradle: Schritt 3, Bild 1 von 3 HTC Vive XR Elite Depth Sensor Replacement, Disconnect the battery cradle: Schritt 3, Bild 2 von 3 HTC Vive XR Elite Depth Sensor Replacement, Disconnect the battery cradle: Schritt 3, Bild 3 von 3
    • Press the release button on the right battery cradle temple slot.
    • Pull the battery cradle away from the right temple slot to disconnect it.
  4. HTC Vive XR Elite Depth Sensor Replacement: Schritt 4, Bild 1 von 3 HTC Vive XR Elite Depth Sensor Replacement: Schritt 4, Bild 2 von 3 HTC Vive XR Elite Depth Sensor Replacement: Schritt 4, Bild 3 von 3
    • Repeat the previous step for the left temple slot.
  5. HTC Vive XR Elite Depth Sensor Replacement, Separate the headset and battery cradle: Schritt 5, Bild 1 von 1
    • Separate the headset and battery cradle.
  6. HTC Vive XR Elite Depth Sensor Replacement, Remove the face cushion: Schritt 6, Bild 1 von 3 HTC Vive XR Elite Depth Sensor Replacement, Remove the face cushion: Schritt 6, Bild 2 von 3 HTC Vive XR Elite Depth Sensor Replacement, Remove the face cushion: Schritt 6, Bild 3 von 3
    • The face cushion is attached to the headset with two magnets. You'll feel the pull of the magnets as you remove it.
    • Grip the middle of the face cushion with your fingers and pull back to remove it.
  7. HTC Vive XR Elite Depth Sensor Replacement, Remove the screw covers: Schritt 7, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Remove the screw covers: Schritt 7, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Use tweezers to remove the six screw covers from the right temple.
  8. HTC Vive XR Elite Depth Sensor Replacement, Unfasten the right temple: Schritt 8, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Unfasten the right temple: Schritt 8, Bild 2 von 2
    • Use a T5 Torx screwdriver to remove the six 4.9 mm‑long screws securing the two right temple halves.
    • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing the right hinge cover.
  9. HTC Vive XR Elite Depth Sensor Replacement, Remove the outer hinge cover: Schritt 9, Bild 1 von 3 HTC Vive XR Elite Depth Sensor Replacement, Remove the outer hinge cover: Schritt 9, Bild 2 von 3 HTC Vive XR Elite Depth Sensor Replacement, Remove the outer hinge cover: Schritt 9, Bild 3 von 3
    • Insert the flat end of a spudger in the gap between the right outer and inner hinge covers.
    • Slide the spudger along the gap to separate the clips securing the outer hinge cover.
    • Remove the outer hinge cover.
  10. HTC Vive XR Elite Depth Sensor Replacement, Remove the outer temple: Schritt 10, Bild 1 von 3 HTC Vive XR Elite Depth Sensor Replacement, Remove the outer temple: Schritt 10, Bild 2 von 3 HTC Vive XR Elite Depth Sensor Replacement, Remove the outer temple: Schritt 10, Bild 3 von 3
    • Insert the flat end of a spudger in the gap between the outer and inner temple.
    • Slide the spudger along the gap to separate the clips securing the outer temple.
  11. HTC Vive XR Elite Depth Sensor Replacement: Schritt 11, Bild 1 von 3 HTC Vive XR Elite Depth Sensor Replacement: Schritt 11, Bild 2 von 3 HTC Vive XR Elite Depth Sensor Replacement: Schritt 11, Bild 3 von 3
    • Slide the top of the outer temple out of its slot in the hinge.
  12. HTC Vive XR Elite Depth Sensor Replacement: Schritt 12, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement: Schritt 12, Bild 2 von 2
    Tesa 61395 Tape
    $10.95
    • The speaker is lightly adhered to the outer temple.
    • Rotate the outer temple towards you to access the speaker.
    • Slide the flat end of a spudger under the speaker to separate its adhesive.
    • During reassembly, if your speaker adhesive isn't sticky, use double-sided tape to re-adhere the speaker to the outer temple.
  13. HTC Vive XR Elite Depth Sensor Replacement: Schritt 13, Bild 1 von 3 HTC Vive XR Elite Depth Sensor Replacement: Schritt 13, Bild 2 von 3 HTC Vive XR Elite Depth Sensor Replacement: Schritt 13, Bild 3 von 3
    • Thread the outer temple off of the USB‑C cable and remove it.
  14. HTC Vive XR Elite Depth Sensor Replacement: Schritt 14, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement: Schritt 14, Bild 2 von 2
    • Pull the inner temple out of its slot in the hinge and remove it.
  15. HTC Vive XR Elite Depth Sensor Replacement, Peel the hinge tape: Schritt 15, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Peel the hinge tape: Schritt 15, Bild 2 von 2
    • Use tweezers to peel back the black tape covering one of the inner hinge cover screws.
  16. HTC Vive XR Elite Depth Sensor Replacement, Unfasten the inner hinge cover: Schritt 16, Bild 1 von 1
    • Use a T5 Torx screwdriver to remove the two screws securing the inner hinge cover:
    • One 3.1 mm‑long screw
    • One 4.9 mm‑long screw
  17. HTC Vive XR Elite Depth Sensor Replacement, Remove the inner hinge cover: Schritt 17, Bild 1 von 3 HTC Vive XR Elite Depth Sensor Replacement, Remove the inner hinge cover: Schritt 17, Bild 2 von 3 HTC Vive XR Elite Depth Sensor Replacement, Remove the inner hinge cover: Schritt 17, Bild 3 von 3
    • Rotate the inner hinge cover off its groove in the frame.
    • Thread the inner hinge cover off of the USB-C and speaker cables and remove it.
  18. HTC Vive XR Elite Depth Sensor Replacement, Remove the screw covers: Schritt 18, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Remove the screw covers: Schritt 18, Bild 2 von 2
    • Use tweezers to remove the six screw covers from the left temple.
  19. HTC Vive XR Elite Depth Sensor Replacement, Unfasten the left temple: Schritt 19, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Unfasten the left temple: Schritt 19, Bild 2 von 2
    • Use a T5 Torx screwdriver to remove the six 4.9 mm‑long screws securing the two left temple halves.
    • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing the left hinge cover.
  20. HTC Vive XR Elite Depth Sensor Replacement, Remove the outer hinge cover: Schritt 20, Bild 1 von 3 HTC Vive XR Elite Depth Sensor Replacement, Remove the outer hinge cover: Schritt 20, Bild 2 von 3 HTC Vive XR Elite Depth Sensor Replacement, Remove the outer hinge cover: Schritt 20, Bild 3 von 3
    • Insert the flat end of a spudger in the gap between the left outer and inner hinge covers.
  21. HTC Vive XR Elite Depth Sensor Replacement, Remove the left temple: Schritt 21, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Remove the left temple: Schritt 21, Bild 2 von 2
    • Pull the left temple out of its slot in the hinge.
    • Don't try to fully remove it yet, as it's still connected by a cable.
  22. HTC Vive XR Elite Depth Sensor Replacement: Schritt 22, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement: Schritt 22, Bild 2 von 2
    • Slide the spudger along the gap to separate the plastic clips securing the outer temple.
  23. HTC Vive XR Elite Depth Sensor Replacement: Schritt 23, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement: Schritt 23, Bild 2 von 2
    • Pull the outer temple off of its inner half to completely release its plastic clips.
  24. HTC Vive XR Elite Depth Sensor Replacement: Schritt 24, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement: Schritt 24, Bild 2 von 2
    Tesa 61395 Tape
    $10.95
    • Let the speaker rest next to the headset before continuing.
    • During reassembly, if your speaker adhesive isn't sticky, use Tesa 61395 Tape to re-adhere the speaker to the outer temple.
  25. HTC Vive XR Elite Depth Sensor Replacement, Peel the hinge tape: Schritt 25, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Peel the hinge tape: Schritt 25, Bild 2 von 2
  26. HTC Vive XR Elite Depth Sensor Replacement, Unfasten the inner hinge cover: Schritt 26, Bild 1 von 1
    • One 3.5 mm‑long screw
  27. HTC Vive XR Elite Depth Sensor Replacement, Reposition the inner hinge cover: Schritt 27, Bild 1 von 3 HTC Vive XR Elite Depth Sensor Replacement, Reposition the inner hinge cover: Schritt 27, Bild 2 von 3 HTC Vive XR Elite Depth Sensor Replacement, Reposition the inner hinge cover: Schritt 27, Bild 3 von 3
    • Don't fully remove the inner hinge cover, as it's connected by the volume button cable.
    • Let the cover hang off its volume button cable for now.
  28. HTC Vive XR Elite Depth Sensor Replacement, Unfasten the face plate: Schritt 28, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Unfasten the face plate: Schritt 28, Bild 2 von 2
    • Use a T5 Torx screwdriver to remove the 12 screws securing the face plate:
    • Six 3.5 mm‑long screws
    • Four 4.9 mm‑long screws
    • Two 6.5 mm‑long screws
    • There are two magnets at the top corners of the face plate. As you remove nearby screws, they might stick to them.
  29. HTC Vive XR Elite Depth Sensor Replacement, Unclip the face cover: Schritt 29, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Unclip the face cover: Schritt 29, Bild 2 von 2
    • Insert the flat end of the spudger in the gap between the frame and the bottom right corner of the face cover.
    • Pry up with the spudger to release the clips securing the face cover.
  30. HTC Vive XR Elite Depth Sensor Replacement: Schritt 30, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement: Schritt 30, Bild 2 von 2
    • Repeat the prying process for the middle and bottom left portions of the face cover.
  31. HTC Vive XR Elite Depth Sensor Replacement, Reposition the face cover: Schritt 31, Bild 1 von 3 HTC Vive XR Elite Depth Sensor Replacement, Reposition the face cover: Schritt 31, Bild 2 von 3 HTC Vive XR Elite Depth Sensor Replacement, Reposition the face cover: Schritt 31, Bild 3 von 3
    • Don't fully remove the face cover completely, as it's connected by the proximity sensor cable.
    • Lift the face cover and rotate it over the top of the frame.
    • Lay the face cover face up before continuing.
  32. HTC Vive XR Elite Depth Sensor Replacement, Unfasten the proximity sensor: Schritt 32, Bild 1 von 1
    • Use a T5 Torx screwdriver to remove the two 3.3 mm‑long screws securing the proximity sensor cable.
  33. HTC Vive XR Elite Depth Sensor Replacement, Remove the face cover: Schritt 33, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Remove the face cover: Schritt 33, Bild 2 von 2
    • Remove the face cover.
  34. HTC Vive XR Elite Depth Sensor Replacement, Reposition the lens assembly: Schritt 34, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Reposition the lens assembly: Schritt 34, Bild 2 von 2
    • Pull the two lenses outward so they're as far apart as possible.
  35. HTC Vive XR Elite Depth Sensor Replacement, Unfasten the lens assembly: Schritt 35, Bild 1 von 1
    • Use a T5 Torx screwdriver to remove the four screws securing the lens assembly:
    • Three 4.9 mm‑long screws
    • One 3.3 mm‑long screw
  36. HTC Vive XR Elite Depth Sensor Replacement, Remove the brackets: Schritt 36, Bild 1 von 3 HTC Vive XR Elite Depth Sensor Replacement, Remove the brackets: Schritt 36, Bild 2 von 3 HTC Vive XR Elite Depth Sensor Replacement, Remove the brackets: Schritt 36, Bild 3 von 3
    • The screw brackets are secured with clips and adhesive.
    • Use tweezers to pull the left screw bracket of its post in the frame.
    • This may require some force. Be careful not to scratch any surrounding components.
    • Repeat this process for the right bracket.
    • During reassembly, use tweezers to align the brackets on their posts. Press down with the flat end of a spudger to engage and re-adhere the clips.
  37. HTC Vive XR Elite Depth Sensor Replacement, Reposition the lens assembly: Schritt 37, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Reposition the lens assembly: Schritt 37, Bild 2 von 2
    • Lift the bottom of the lens assembly up to separate the bottom rails from their slots in the frame.
  38. HTC Vive XR Elite Depth Sensor Replacement: Schritt 38, Bild 1 von 3 HTC Vive XR Elite Depth Sensor Replacement: Schritt 38, Bild 2 von 3 HTC Vive XR Elite Depth Sensor Replacement: Schritt 38, Bild 3 von 3
    • Pull the lens assembly upwards to separate the top rails from their slots in the frame.
    • Rotate the lens assembly towards the top of the frame so it sits upright with its cable connectors exposed.
  39. HTC Vive XR Elite Depth Sensor Replacement, Unfasten the lens assembly cables: Schritt 39, Bild 1 von 1
    • Use a T5 Torx screwdriver to remove the four 3.4 mm‑long screws securing the lens assembly cables.
  40. HTC Vive XR Elite Depth Sensor Replacement, Disconnect the lens assembly cables: Schritt 40, Bild 1 von 3 HTC Vive XR Elite Depth Sensor Replacement, Disconnect the lens assembly cables: Schritt 40, Bild 2 von 3 HTC Vive XR Elite Depth Sensor Replacement, Disconnect the lens assembly cables: Schritt 40, Bild 3 von 3
    • Use the flat end of a spudger to pry up and disconnect the lens assembly cable connector.
    • Repeat this procedure for the other connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  41. HTC Vive XR Elite Depth Sensor Replacement, Remove the lens assembly: Schritt 41, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Remove the lens assembly: Schritt 41, Bild 2 von 2
    • Lift up and remove the lens assembly.
  42. HTC Vive XR Elite Depth Sensor Replacement, Reassembly information: Schritt 42, Bild 1 von 3 HTC Vive XR Elite Depth Sensor Replacement, Reassembly information: Schritt 42, Bild 2 von 3 HTC Vive XR Elite Depth Sensor Replacement, Reassembly information: Schritt 42, Bild 3 von 3
    • The next four steps demonstrate how to secure the lens assembly to the frame during reassembly.
    • In order for the lens assembly to rest in the frame properly, it needs to align with a peg in the IPD (interpupillary distance) slider.
    • Before reinstalling the lens assembly, push the IPD slider to its right-most position.
  43. HTC Vive XR Elite Depth Sensor Replacement: Schritt 43, Bild 1 von 3 HTC Vive XR Elite Depth Sensor Replacement: Schritt 43, Bild 2 von 3 HTC Vive XR Elite Depth Sensor Replacement: Schritt 43, Bild 3 von 3
    • Pull the lens assembly outward until its plastic clips sit close to the end of the top rails.
    • You may need to push and pull the top rail so it sits evenly across the plastic clips.
  44. HTC Vive XR Elite Depth Sensor Replacement: Schritt 44, Bild 1 von 3 HTC Vive XR Elite Depth Sensor Replacement: Schritt 44, Bild 2 von 3 HTC Vive XR Elite Depth Sensor Replacement: Schritt 44, Bild 3 von 3
    • Push the bottom rails inwards as far as they will go.
  45. HTC Vive XR Elite Depth Sensor Replacement: Schritt 45, Bild 1 von 3 HTC Vive XR Elite Depth Sensor Replacement: Schritt 45, Bild 2 von 3 HTC Vive XR Elite Depth Sensor Replacement: Schritt 45, Bild 3 von 3
    • To secure the lens assembly into the frame:
    • Slide the top left rail into its slot.
    • Align the other rails.
    • Press the lens assembly into place, making sure to realign the center peg.
  46. HTC Vive XR Elite Depth Sensor Replacement, Peel the tape: Schritt 46, Bild 1 von 3 HTC Vive XR Elite Depth Sensor Replacement, Peel the tape: Schritt 46, Bild 2 von 3 HTC Vive XR Elite Depth Sensor Replacement, Peel the tape: Schritt 46, Bild 3 von 3
  47. HTC Vive XR Elite Depth Sensor Replacement: Schritt 47, Bild 1 von 1
    • Peel off the yellow tape covering the proximity sensor connector.
  48. HTC Vive XR Elite Depth Sensor Replacement, Disconnect the proximity sensor: Schritt 48, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Disconnect the proximity sensor: Schritt 48, Bild 2 von 2
    • Use the point of a spudger to lift up the locking flap on the proximity sensor ZIF connector.
  49. HTC Vive XR Elite Depth Sensor Replacement: Schritt 49, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement: Schritt 49, Bild 2 von 2
    • Use tweezers to pull the proximity sensor cable out of its slot in the motherboard.
  50. HTC Vive XR Elite Depth Sensor Replacement, Remove the proximity sensor: Schritt 50, Bild 1 von 1
    • Remove the proximity sensor.
  51. HTC Vive XR Elite Depth Sensor Replacement, Peel the tape: Schritt 51, Bild 1 von 3 HTC Vive XR Elite Depth Sensor Replacement, Peel the tape: Schritt 51, Bild 2 von 3 HTC Vive XR Elite Depth Sensor Replacement, Peel the tape: Schritt 51, Bild 3 von 3
    • Peel off the yellow tape covering the motion sensor cable.
  52. HTC Vive XR Elite Depth Sensor Replacement, Unfasten the motion sensor: Schritt 52, Bild 1 von 1
    • Use a T5 Torx screwdriver to remove the two 3.4 mm‑long screws securing the motion sensor.
  53. HTC Vive XR Elite Depth Sensor Replacement, Reposition the motion sensor: Schritt 53, Bild 1 von 3 HTC Vive XR Elite Depth Sensor Replacement, Reposition the motion sensor: Schritt 53, Bild 2 von 3 HTC Vive XR Elite Depth Sensor Replacement, Reposition the motion sensor: Schritt 53, Bild 3 von 3
    • Don't try to fully remove the motion sensor yet, as it's still connected by a cable.
    • Lift the motion sensor off its pegs in the frame.
    • Flip over the motion sensor and lay it on the frame before continuing.
  54. HTC Vive XR Elite Depth Sensor Replacement, Peel the tape: Schritt 54, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Peel the tape: Schritt 54, Bild 2 von 2
    • Peel off the yellow tape covering the motion sensor cable connector.
  55. HTC Vive XR Elite Depth Sensor Replacement, Disconnect the motion sensor: Schritt 55, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Disconnect the motion sensor: Schritt 55, Bild 2 von 2
    • Use the point of a spudger to lift up the locking flap on the motion sensor ZIF connector.
  56. HTC Vive XR Elite Depth Sensor Replacement, Remove the motion sensor: Schritt 56, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Remove the motion sensor: Schritt 56, Bild 2 von 2
    • Use tweezers to pull the motion sensor cable connector out of its slot.
    • Remove the motion sensor.
  57. HTC Vive XR Elite Depth Sensor Replacement, Disconnect the right speaker: Schritt 57, Bild 1 von 3 HTC Vive XR Elite Depth Sensor Replacement, Disconnect the right speaker: Schritt 57, Bild 2 von 3 HTC Vive XR Elite Depth Sensor Replacement, Disconnect the right speaker: Schritt 57, Bild 3 von 3
    • Use tweezers to pull the right speaker connector out of its socket.
    • If you're having trouble, try rocking the connector side-to-side to help loosen it.
  58. HTC Vive XR Elite Depth Sensor Replacement, Remove the right speaker: Schritt 58, Bild 1 von 1
    • Remove the right speaker.
  59. HTC Vive XR Elite Depth Sensor Replacement, Disconnect the left speaker: Schritt 59, Bild 1 von 3 HTC Vive XR Elite Depth Sensor Replacement, Disconnect the left speaker: Schritt 59, Bild 2 von 3 HTC Vive XR Elite Depth Sensor Replacement, Disconnect the left speaker: Schritt 59, Bild 3 von 3
    • Use tweezers to pull the left speaker connector out of its socket.
  60. HTC Vive XR Elite Depth Sensor Replacement, Remove the left speaker: Schritt 60, Bild 1 von 1
    • Remove the left speaker.
  61. HTC Vive XR Elite Depth Sensor Replacement, Separate the volume button cable: Schritt 61, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Separate the volume button cable: Schritt 61, Bild 2 von 2
    • The volume button cable is lightly adhered to the left inner hinge cover.
    • Insert one arm of your tweezers between the volume button cable and the hinge cover.
    • Pry away from the hinge cover to separate the adhesive.
  62. HTC Vive XR Elite Depth Sensor Replacement: Schritt 62, Bild 1 von 3 HTC Vive XR Elite Depth Sensor Replacement: Schritt 62, Bild 2 von 3 HTC Vive XR Elite Depth Sensor Replacement: Schritt 62, Bild 3 von 3
    • Use your tweezers to pull the volume button cable out of its slot in the hinge cover.
  63. HTC Vive XR Elite Depth Sensor Replacement, Disconnect the bottom left antenna: Schritt 63, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Disconnect the bottom left antenna: Schritt 63, Bild 2 von 2
    • Use one arm of your tweezers to pry up and disconnect the bottom left antenna cable.
    • During reassembly, these can be tricky to reconnect. Hold the connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  64. HTC Vive XR Elite Depth Sensor Replacement, Reposition the bottom left antenna cable: Schritt 64, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Reposition the bottom left antenna cable: Schritt 64, Bild 2 von 2
  65. HTC Vive XR Elite Depth Sensor Replacement, Unfasten the motion sensor bracket: Schritt 65, Bild 1 von 1
    • Use a T5 Torx screwdriver to remove the two 4.9 mm‑long screws securing the motion sensor bracket.
  66. HTC Vive XR Elite Depth Sensor Replacement, Remove the motion sensor bracket: Schritt 66, Bild 1 von 3 HTC Vive XR Elite Depth Sensor Replacement, Remove the motion sensor bracket: Schritt 66, Bild 2 von 3 HTC Vive XR Elite Depth Sensor Replacement, Remove the motion sensor bracket: Schritt 66, Bild 3 von 3
    • Lift the motion sensor off its pegs on the motherboard.
    • Remove the motion sensor bracket.
  67. HTC Vive XR Elite Depth Sensor Replacement, Peel the tape: Schritt 67, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Peel the tape: Schritt 67, Bild 2 von 2
    • Use tweezers to peel back the gray conductive tape covering the left side‑camera ZIF connector.
  68. HTC Vive XR Elite Depth Sensor Replacement: Schritt 68, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement: Schritt 68, Bild 2 von 2
    • Use tweezers to peel off the black tape covering the left side‑camera ZIF connector.
  69. HTC Vive XR Elite Depth Sensor Replacement, Disconnect the left side camera: Schritt 69, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Disconnect the left side camera: Schritt 69, Bild 2 von 2
    • Use flat end of a spudger to lift up the locking flap on the left side‑camera ZIF connector.
  70. HTC Vive XR Elite Depth Sensor Replacement: Schritt 70, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement: Schritt 70, Bild 2 von 2
    • Use tweezers to pull the left side‑camera cable connector out of its slot in the motherboard.
  71. HTC Vive XR Elite Depth Sensor Replacement, Peel the tape: Schritt 71, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Peel the tape: Schritt 71, Bild 2 von 2
    • Use tweezers to peel back the gray conductive tape covering the left tracking camera ZIF connector.
  72. HTC Vive XR Elite Depth Sensor Replacement: Schritt 72, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement: Schritt 72, Bild 2 von 2
    • Use tweezers to peel off the black tape covering the left tracking camera ZIF connector.
  73. HTC Vive XR Elite Depth Sensor Replacement, Disconnect the left tracking camera: Schritt 73, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Disconnect the left tracking camera: Schritt 73, Bild 2 von 2
    • Use a spudger to lift up the locking flap on the left tracking camera ZIF connector.
  74. HTC Vive XR Elite Depth Sensor Replacement: Schritt 74, Bild 1 von 1
    • Use tweezers to pull the left tracking camera cable connector out of its slot in the motherboard.
  75. HTC Vive XR Elite Depth Sensor Replacement, Disconnect the antennas: Schritt 75, Bild 1 von 3 HTC Vive XR Elite Depth Sensor Replacement, Disconnect the antennas: Schritt 75, Bild 2 von 3 HTC Vive XR Elite Depth Sensor Replacement, Disconnect the antennas: Schritt 75, Bild 3 von 3
  76. HTC Vive XR Elite Depth Sensor Replacement, Peel the tape: Schritt 76, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Peel the tape: Schritt 76, Bild 2 von 2
  77. HTC Vive XR Elite Depth Sensor Replacement: Schritt 77, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement: Schritt 77, Bild 2 von 2
    • Use tweezers to peel off the black tape covering the pass-through camera ZIF connector.
  78. HTC Vive XR Elite Depth Sensor Replacement, Disconnect the pass-through camera: Schritt 78, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Disconnect the pass-through camera: Schritt 78, Bild 2 von 2
    • Use a spudger to lift up the locking flap on the pass-through camera ZIF connector.
  79. HTC Vive XR Elite Depth Sensor Replacement: Schritt 79, Bild 1 von 1
    • Use tweezers to pull the pass-through camera cable connector out of its slot in the motherboard.
  80. HTC Vive XR Elite Depth Sensor Replacement, Peel the tape: Schritt 80, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Peel the tape: Schritt 80, Bild 2 von 2
  81. HTC Vive XR Elite Depth Sensor Replacement, Disconnect the microphone: Schritt 81, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Disconnect the microphone: Schritt 81, Bild 2 von 2
    • Use the point of a spudger to lift up the locking flap on the microphone ZIF connector.
  82. HTC Vive XR Elite Depth Sensor Replacement: Schritt 82, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement: Schritt 82, Bild 2 von 2
    • Use tweezers to pull the microphone cable connector out of its slot in the motherboard.
  83. HTC Vive XR Elite Depth Sensor Replacement, Disconnect the depth sensor: Schritt 83, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Disconnect the depth sensor: Schritt 83, Bild 2 von 2
    • Use tweezers to pull the depth sensor cable connector out of its slot in the motherboard.
  84. HTC Vive XR Elite Depth Sensor Replacement, Peel the tape: Schritt 84, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Peel the tape: Schritt 84, Bild 2 von 2
    • Use tweezers to peel back the gray conductive tape covering the right tracking camera ZIF connector.
  85. HTC Vive XR Elite Depth Sensor Replacement: Schritt 85, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement: Schritt 85, Bild 2 von 2
    • Use tweezers to peel off the black tape covering the right tracking camera ZIF connector.
  86. HTC Vive XR Elite Depth Sensor Replacement, Disconnect the right tracking camera: Schritt 86, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Disconnect the right tracking camera: Schritt 86, Bild 2 von 2
    • Use a spudger to lift up the locking flap on the right tracking camera ZIF connector.
  87. HTC Vive XR Elite Depth Sensor Replacement: Schritt 87, Bild 1 von 1
    • Use tweezers to pull the right tracking camera cable connector out of its slot.
  88. HTC Vive XR Elite Depth Sensor Replacement, Peel the tape: Schritt 88, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Peel the tape: Schritt 88, Bild 2 von 2
    • Use tweezers to peel back the gray conductive tape covering the right side‑camera ZIF connector.
  89. HTC Vive XR Elite Depth Sensor Replacement: Schritt 89, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement: Schritt 89, Bild 2 von 2
    • Use tweezers to peel off the black tape covering the right side‑camera ZIF connector.
  90. HTC Vive XR Elite Depth Sensor Replacement, Disconnect the right side camera: Schritt 90, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Disconnect the right side camera: Schritt 90, Bild 2 von 2
    • Use a spudger to lift up the locking flap on the right side-camera ZIF connector.
  91. HTC Vive XR Elite Depth Sensor Replacement: Schritt 91, Bild 1 von 1
    • Use tweezers to pull the right side‑camera cable connector out of its slot.
  92. HTC Vive XR Elite Depth Sensor Replacement, Unfasten the motherboard frame: Schritt 92, Bild 1 von 1
    • Use a T5 Torx screwdriver to remove the two 4.9 mm‑long screws securing the motherboard frame.
  93. HTC Vive XR Elite Depth Sensor Replacement, Tape the cables: Schritt 93, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Tape the cables: Schritt 93, Bild 2 von 2
    • Use tape with light adhesive, such as painter's tape, to keep the left and right side cables away from the motherboard.
    • The cables near the top edge need slack for the motherboard to rest properly in the frame. Avoid taping them tightly—or avoid taping them altogether.
  94. HTC Vive XR Elite Depth Sensor Replacement, Disconnect the power button: Schritt 94, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Disconnect the power button: Schritt 94, Bild 2 von 2
    • Lift the power button out of its slot in the frame.
    • Don't remove the button completely, as it's still attached by a cable.
  95. HTC Vive XR Elite Depth Sensor Replacement, Remove the IPD slider: Schritt 95, Bild 1 von 2 HTC Vive XR Elite Depth Sensor Replacement, Remove the IPD slider: Schritt 95, Bild 2 von 2
    • Press down the bottom right corner of the motherboard so its edge rests under the IPD slider.
  96. HTC Vive XR Elite Depth Sensor Replacement: Schritt 96, Bild 1 von 3 HTC Vive XR Elite Depth Sensor Replacement: Schritt 96, Bild 2 von 3 HTC Vive XR Elite Depth Sensor Replacement: Schritt 96, Bild 3 von 3
    • While pressing down on the motherboard, push the IPD slider out of its slot in the frame.
    • Remove the IPD slider.
  97. HTC Vive XR Elite Depth Sensor Replacement, Remove the motherboard assembly: Schritt 97, Bild 1 von 3 HTC Vive XR Elite Depth Sensor Replacement, Remove the motherboard assembly: Schritt 97, Bild 2 von 3 HTC Vive XR Elite Depth Sensor Replacement, Remove the motherboard assembly: Schritt 97, Bild 3 von 3
    • Grip the USB-C port with one hand and the right side of the frame with the other.
    • Pull the frame outward while lifting the motherboard assembly until it clears its slot next to the right side‑camera.
    • Use a spudger to pry up the motherboard assembly until its right side completely clears the frame.
  98. HTC Vive XR Elite Depth Sensor Replacement: Schritt 98, Bild 1 von 3 HTC Vive XR Elite Depth Sensor Replacement: Schritt 98, Bild 2 von 3 HTC Vive XR Elite Depth Sensor Replacement: Schritt 98, Bild 3 von 3
    • Pull the right side of the motherboard assembly toward the bottom edge of the device to separate it from the frame.
    • Remove the motherboard assembly.
    • During reassembly, make sure the cables stay above the motherboard assembly as you reinstall it.
  99. HTC Vive XR Elite Depth Sensor Replacement, Unfasten the depth sensor: Schritt 99, Bild 1 von 1
    • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing the depth sensor.
  100. HTC Vive XR Elite Depth Sensor Replacement, Remove the depth sensor: Schritt 100, Bild 1 von 3 HTC Vive XR Elite Depth Sensor Replacement, Remove the depth sensor: Schritt 100, Bild 2 von 3 HTC Vive XR Elite Depth Sensor Replacement, Remove the depth sensor: Schritt 100, Bild 3 von 3
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Alex Diaz-Kokaisl
227.484 Reputation
1.106 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
124 Mitglieder
24.300 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 269
