Einleitung
Follow this guide to replace the headstraps in your HTC Vive XR Elite battery cradle.
If your battery is swollen, take appropriate precautions.
Was du brauchst
Press the release button on the right battery cradle temple slot.
Pull the battery cradle away from the right temple slot to disconnect it.
Separate the headset and battery cradle.
Insert a long edge of an opening pick in the gap between the two halves of the battery cradle, near the USB-C cable.
Slide the opening pick along the top edge of battery cradle to release its plastic clips.
Flip the battery cradle over.
Insert the long edge of an opening pick in the gap between the two halves of the battery cradle.
Slide the opening pick along the bottom edge of battery cradle to release its plastic clips.
Pull apart the two halves of the battery cradle to completely separate them.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use tweezers to peel back the graphite thermal tape covering the inner plastic frame.
In diesem Schritt verwendetes Werkzeug:FixMat$36.95
Use a T5 Torx screwdriver to remove the nine screws securing the inner plastic frame:
Five 11.8 mm-long screws
Three 5.6 mm-long screws
One 5.6 mm-long screw
Remove the inner plastic frame, making sure to thread the graphite thermal tape through it.
Use a T5 Torx screwdriver to remove the two 5.6 mm-long screws securing the headstrap clips.
Use tweezers to remove the left and right headstrap clips.
Use tweezers or your fingers to peel back the thermal pad covering the battery board.
Use the flat end of a spudger to push the left and right battery cell connectors out of their respective sockets.
Use the point of a spudger to flip up the locking flap on the power LED ZIF connector.
Use tweezers or your fingers to disconnect the power LED cable.
Pull the black tab straight up on the USB-C power cable to disconnect it.
Use tweezers or your fingers to peel the conductive tape away from the front metal battery enclosure.
Use a T5 Torx screwdriver to remove the four 4.1 mm-long screws securing the battery board.
Use a T5 Torx screwdriver to remove the three screws securing the front metal battery enclosure:
Two 11.8 mm-long screws
One 4.8 mm-long screw
Slide the USB-C power cable to the left to unclip it.
Remove the front metal battery enclosure.
Stand the battery cradle upright so the battery cells can fold flat on your work surface.
Peel off the graphite thermal tape covering the right battery cell.
Remove the right battery cell.
Repeat the previous step for the left battery cell.
Grip the center plastic screw spacer with your fingers.
Remove the rear metal battery enclosure.
Hold one end of the USB-C power cable and pull it straight back to unclip it.
Remove the USB-C power cable.
In diesem Schritt verwendetes Werkzeug:Tesa 61395 Tape$2.99
Insert an opening pick under the adjustment dial faceplate.
Pry up to separate the adhesive securing the faceplate.
Remove the faceplate.
Use tweezers to remove the plastic tape covering the adjustment dial screw.
Use a Torx T5 screwdriver to remove the 3.8 mm-long screw securing the adjustment dial.
Insert an opening pick between the adjustment dial and the screw spacer.
Pry the screw spacer away from the adjustment dial to remove it.
Pull the adjustment dial straight off the cradle and remove it.
Use the point of a spudger to pry up the center of the sprocket.
Remove the adjustment dial sprocket.
Three adjustment dial pegs
Three sprocket cutouts
Use a T5 Torx screwdriver to remove the four 4.1 mm-long screws securing the headstrap guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
